SolaraGuy.com • View topic - HID HELP
HID HELP
HID HELP
Postby Bippusol » Thu Nov 17, 2011 5:06 pm
picking up some HID's from a local shop soon
I've done research and I still have questions:
Can I install HID's in my stock Gen1 reflector housing?
Is there a DIY to eliminate the bottom glare?
what temp should I go with?
money is tight so i really don't wanna spend too much on making/buying the projectors, can the bottom glare be eliminated via another solution?
I was really looking forward to payin around 70$ for them, and plug & play and be done with it.
But my concern is glaring the $hit out of other drivers & getting a ticket for them :b
I was thinking 5k or 6k. Likes? Dislikes?
01 SE-V6, Stock as Fock (=
Bippusol
Re: HID HELP
Postby Bippusol » Thu Nov 17, 2011 5:07 pm
:toy:
Bippusol
Re: HID HELP
Postby ThatVietGuy » Thu Nov 17, 2011 7:29 pm
Like 99% of the people with HIDs on a Gen 1 have NOT gone the retrofit route.
And no, you cannot get rid of any of the imperfections without going projectors.
And to keep from blinding other drivers, park 20 ft or so away from a wall on a level surface and aim the lights down. There's a grey screw on the back of the housing that will let you do this. I believe it's CCW for going down, CW for going up.
ThatVietGuy
Re: HID HELP
Postby Bippusol » Thu Nov 17, 2011 7:40 pm
ThatVietGuy wrote:Like 99% of the people with HIDs on a Gen 1 have NOT gone the retrofit route.
so everyones glaring people & $hit? :drinking:
Bippusol
Re: HID HELP
Postby dinoxor » Thu Nov 17, 2011 10:53 pm
I have hids on stock housing and it's not that bad I angled it down a bit like the post above mentioned but not a lot to noticed a difference.
However I have never had anyone high beamed me before and had it for almost a year.
The only input I would add is to get 30 or 35 watt one and not get the 50w one where it'll be super bright so check with whoever you're buying from to see what's the watt output
dinoxor
Re: HID HELP
Postby Bippusol » Thu Nov 17, 2011 11:04 pm
dinoxor wrote:I have hids on stock housing and it's not that bad I angled it down a bit like the post above mentioned but not a lot to noticed a difference.
is there a bulb clip i have to bend to angle it?
thanks for the input bro! def look into that
Bippusol
Re: HID HELP
Postby Bippusol » Fri Nov 18, 2011 1:45 am
ThatVietGuy wrote:And to keep from blinding other drivers, park 20 ft or so away from a wall on a level surface and aim the lights down. There's a grey screw on the back of the housing that will let you do this. I believe it's CCW for going down, CW for going up.
thanks man!
Bippusol
Re: HID HELP
Postby EkiMucH » Fri Nov 18, 2011 1:52 am
I have 35watt 6000k on my car, been highbeamed from incoming traffic at the light before and also a cop put his spotlight on me while I drove out of work one night, but haven't gotten a ticket yet *knocks on wood*. Once in awhile I will check that the light angle isn't pointed too high. Planning to go with a 5k soon.
EkiMucH
Re: HID HELP
Postby Bippusol » Fri Nov 18, 2011 4:11 am
EkiMucH wrote:I have 35watt 6000k on my car, been highbeamed from incoming traffic at the light before and also a cop put his spotlight on me while I drove out of work one night, but haven't gotten a ticket yet *knocks on wood*. Once in awhile I will check that the light angle isn't pointed too high. Planning to go with a 5k soon.
thanks for the input man.
surprised you havent gotten a ticket, being in cali and all
Bippusol
Re: HID HELP
Postby dinoxor » Sat Nov 19, 2011 3:15 am
you can search the forum i remember finding a post about how to angle your headlights
hopefully this helps too http://forums.clubrsx.com/showthread.php?t=169724
that diagram helps me a lot!
dinoxor
Re: HID HELP
Postby Bippusol » Sat Nov 19, 2011 6:15 pm
dinoxor wrote:you can search the forum i remember finding a post about how to angle your headlights
thanks a lot bro!
Bippusol
Re: HID HELP
Postby Bippusol » Tue Nov 22, 2011 5:04 pm
local shop says I need h4 bulbs. I've read on here h3/9003. can anyone verify if thats true. will h4 bulbs fit in my gen 1?
Bippusol
Re: HID HELP
Postby ThatVietGuy » Tue Nov 22, 2011 7:23 pm
Your local shop has idiots working for it. It's 9003.
ThatVietGuy
Re: HID HELP
Postby Bippusol » Tue Nov 22, 2011 8:15 pm
ThatVietGuy wrote:Your local shop has idiots working for it. It's 9003.
x2. ima just fight em if not, I'll purchase em somewhere else. ty
Bippusol
Re: HID HELP
Postby Bippusol » Sun Nov 27, 2011 4:15 am
finally got my hids! decided to go w/ 6k bulbs
w/o fogs
w/ fogs
before i adjusted the drivers side bulb lol & fogs
[sorry for the $hitty crackberry quality pictures]
Bippusol
Users browsing this forum: No registered users and 79 guests
