SolaraGuy.com • View topic - "Check Engine" light has come ON!! HEEEEEELLLLPPP
Postby that1mexguy » Thu Sep 11, 2003 6:44 pm
Aight, yesterday a couple of friends that supposibly "know" about cars helped me install a short ram intake for my car. Everything seemed to be working fine, for at least 2 hrs or so, but then on my way home, the car simply died on me so i had to leave it parked and took a cab home. This morning my best friend picked it up for me and told me that it was running fine and that it started with no problem, however, as soon as i got home, i put the stock intake back (im not taking any chances again) but now the "check engine" light has come on..... is there any way to reset it? or should i just take it to the dealership and let them figure it out and probably charge me tons of $$? :( (i guess that's what i get for buying eBay stuff) :roll:
that1mexguy
Postby Turbosolara » Thu Sep 11, 2003 7:19 pm
disconnect the battery for 10 minutes and then let it idle for another 10 minutes, you are done with reseting computer. i think your car has loose vacuum line or intake hose that cause it stall on you.
Postby Akfahad » Fri Sep 12, 2003 6:42 am
I'm not exactly mechanically inclined on cars, but I was told, after installing the Injen intake, that the engine light would come on. All it needed was a couple of key turns and just some routine driving and it eventually worked. When I took the Injen off and put the factory one again (just cause i wasn't happy with it anymore) i had to do the same thing - just some routine driving (a couple of miles) and a couple of key turns and the engine light turned right off. But...my car never just died on me. :-?
Postby SC V6 » Fri Sep 12, 2003 7:48 am
I never had a problem, and I have had my injen intake on and off about 6 times
SC V6
Postby DavPak » Fri Sep 12, 2003 10:19 am
no probs with my Injen. not even a check engine light.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Yanks0114 » Fri Sep 12, 2003 10:53 am
DavPak wrote:no probs with my Injen. not even a check engine light.
But did you reset the battery when u installed it.
20 starts and the CE light resets
Postby DavPak » Fri Sep 12, 2003 12:15 pm
Yanks0114 wrote:But did you reset the battery when u installed it.
no i didn't.
the 20 start thing has to do with the fuel/evap system. not necessarily with other onboard systems.
DavPak
Postby Hsakuragi » Fri Sep 12, 2003 9:29 pm
just remove the # 15 fuse... EFI or something like that, that's better than removing the battery...
Hsakuragi
Postby Turbosolara » Sat Sep 13, 2003 10:41 am
hsakuragi wrote:just remove the # 15 fuse... EFI or something like that, that's better than removing the battery...
People always told me just remove the fuse, but i kinda doubt about it. I mean if you look at your ECU, there were about 4 or more power resource on the ECU (one on each connector and several grounds). What about the EFI fuse only disconnect one power resource from ECU and while other 3 fuses still have power supply into the ECU. I was thinking maybe to totally disconnect the power resource will be better
Postby HKSV6SLE » Sat Sep 13, 2003 2:47 pm
hey u never know..just drive your car around.....and the light might just turn off...i took a sharp left turn....with my car sliding..and my engine light turned on..and the traction control turned off too...i drove around with the check engine light on...then i was curious how much the dealer would want to check the problem out for....and oh yea don't ever go to puentte hills toyota in city of industry...those dumbf*cks wanted 90 bucks....just to figure out was wrong...so anyways....i just drove with it on some more...then....one day i did the same thing...i took a sharp turn really fast.....slid thru the turn..and all the lights turned off.....so i dunno what that did...but everything is fine now....next time..if it turns on im gonna get one of thsoe code reader things...to find it out myself.....90 bucks mah ass....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
thanks guy
Postby that1mexguy » Sat Sep 13, 2003 11:08 pm
hey guys, i actually ended up unplugin the battery for like 15 mins or so and when i plugged it back, like nothing, problem solved. :D tomorrow, i'll be messing around with my new reversable gauges, wish me luck!! :)
that1mexguy
