SolaraGuy.com • View topic - wheel numbers
wheel numbers
wheel numbers
Postby lupous » Fri Sep 12, 2003 10:15 am
i'm sorry, but i'm just not really good at all this upgrade information, and now i feel like a dumba$$
what do the numbers that go with rim and wheels mean?
for example
"Wheel & Tire Package Price comes with 205-40-17 tires. Eagle 193 wheels are 4x100 4x114.3"
lupous
Re: wheel numbers
Postby DavPak » Fri Sep 12, 2003 10:23 am
lupous wrote:i'm sorry, but i'm just not really good at all this upgrade information, and now i feel like a dumba$$
for example
205 = width
40 = height from rim (as a percentage of the width)
17 = rim size (17" in this case)
an "R" before the rim size indicates "Radial" tires, which most are!
a "P" before the width indicates "Passenger" tire (ooposed to truck tires)
eagle 193 = wheel model
4 = lug pattern (4 lug/5 lug)
100 or 114.3 = hub offset (with zero being the hub equal to the lip of the rim)
there should be a website that describes all this, just can't seem to find it now!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby impactX » Fri Sep 12, 2003 2:07 pm
The 114.3 means the distance between the lugs from top to bottom.
impactX
Postby lupous » Sat Sep 13, 2003 10:05 pm
thanks, i seearched for this and just couldn't come up with anythingllland it seems like you know alot more than any of my friends on the subject.....
ii know we use five lug, but are there any other specifications that pertain to the solara as far as tires go?
larry
lupous
Postby HKSV6SLE » Sun Sep 14, 2003 2:15 am
very good moderators....the only thing you might wanna look out for..is "plus sizing" correctly...meaning when you get 17's for example that your tire size is the same...as the stock size....so your gauges and stuff are still right...uh...can someone else clarify it...the plus sziing....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby FLASH » Sun Sep 14, 2003 6:33 am
HKSV6SLE wrote:uh...can someone else clarify it...the plus sziing....
Yes..someone please do... :cry: I think he's reffering to offset?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby JoeB » Sun Sep 14, 2003 6:46 am
No, he's talking about the diameter of the wheel/tire. If you started with a 16" wheel and tire setup with 60s(?), look at the second number that DavPak mentions (hight from rim =40). That number is smaller to keep an overall same diameter of the tire as you increase the wheel size to say 18". Since the wheel is now larger, you need a smaller hight tire to keep the overall diameter the same. I'm not sure of the exact numbers but you should get the concept. If the diameter of the wheel changes, your speedometer and odometer will be off. -JoeB
JoeB
Postby HKSV6SLE » Sun Sep 14, 2003 12:04 pm
yea....the overall diameter...all i know is that my car came with 205/60r 16's i think the re92's....to plus size it one more you would need to get 215 55r 16 basically getting a wider tire and the height (profile) of the tire lower....i think when you go up to 17 th eproper size is 215 or 225 55/50 to have the right size....something like that.....you dont have to follow that..but you probably should...
www.lexusnet.com
HKSV6SLE
Postby mailskobe » Mon Sep 15, 2003 5:07 pm
go to whalentire.com put in your car model and it will give you stock size and plus size options. it will tell you how much your speedo will be inaccurate and all that stuff.
you can also go to 1010tires.com and again input your car details to get stock sizes and plus sizes. this site doesnt have the details tho.
2000 SZ V6, 5 speed, silver
mailskobe
Users browsing this forum: No registered users and 78 guests
