SolaraGuy.com • View topic - Obx Header leak
Obx Header leak
Obx Header leak
Postby Brandoe91 » Tue Jan 10, 2012 9:00 pm
Codes
P0171 bank 1 system too lean and misfire codes for cylinder 1 3 and 5 (all on bank 1).
I tested for vacuum leaks, fuel pressure ,change plugs, pvc , valve cover gaskets etc. Codes kept coming back.
Today I took a picture of the rear header and it seems l might have found an exhaust leak(black soot at the header). I think the leak might be throwing off bank 1 sensor 1 reading, thus causing bank one to run lean and randomly misfire. What do you guys think?
Don't mind leak and loose nut, I already replaced valve cover gasket just never cleaned back there.
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Re: Obx Header leak
Postby chullen1 » Wed Jan 11, 2012 7:08 am
I HAVE SEEN THIS BEFORE ON MY SET, LOOK FOR THE EGR PIPE AND SEE IF THAT BROKE OFF SINCE THIS IS COMMON.
chullen1
Re: Obx Header leak
Postby 1gSE » Wed Jan 11, 2012 7:49 am
did you replace the header gasket too?
Solara-M62 @ 5.5psi
1gSE
Re: Obx Header leak
Postby TRD_Sloara » Wed Jan 11, 2012 5:11 pm
Wait, why is the top stud nut almost off of the stud? Shouldn't that be tightened down? It looks like that is where it is leaking.
The gasket looks new to me. I almost feel like captain obvious pointing out the nut, but assuming the car was driven like this, I'm about 98% sure that would be the culprit.
TRD_Sloara
Re: Obx Header leak
Postby Brandoe91 » Wed Jan 11, 2012 6:22 pm
Egr is fine. Where was yours leaking from and did you have any codes?
chullen1 wrote:I HAVE SEEN THIS BEFORE ON MY SET, LOOK FOR THE EGR PIPE AND SEE IF THAT BROKE OFF SINCE THIS IS COMMON.
When I initial installed the headers couple months back, but since I've seen the leak no. I will fix it at the end of the week and hope it will fix my problems. Then BOOOST :lol:
1gSE wrote:did you replace the header gasket too?
Ye i stated it was loose but good eye all the same. I also think it's the culprit, as you can see the black soot (exhaust leak) in the same area.I just wanted to know if you guys think the leak is causing the lean code. I know an exhaust leak before 02 sensor can cause a lean condition but my leak seems small. So I am not sure.
TRD_Sloara wrote: Wait, why is the top stud nut almost off of the stud? Shouldn't that be tightened down? It looks like that is where it is leaking.
Brandoe91
Re: Obx Header leak
Postby chullen1 » Thu Jan 12, 2012 1:33 pm
I HAD A EGR CODE WHEN MY HEADERS DID GO, I HAD THEM ON FOR ABOUT A YEAR IN EAST COAST CLIMATE AND THEY BROKE AT THE EGR PIPE ATTACHMENT AND THE FRONT HEADER CRACKED AT THE WELD.
chullen1
Re: Obx Header leak
Postby TheGreenDutch » Sat Jan 14, 2012 11:32 am
those OBX headers are too fragile.
TheGreenDutch
Re: Obx Header leak
Postby Brandoe91 » Thu Jan 19, 2012 2:40 pm
Tightened the nut but the same codes came back on after a couple miles . Do guys think I should replace the header gasket?
Brandoe91
Re: Obx Header leak
Postby 1gSE » Fri Jan 20, 2012 2:59 am
I would. But before that, I would run a can of SeaFoam through it to pin the leak just in case its coming from somewhere else
Solara-M62 @ 5.5psi
1gSE
Re: Obx Header leak
Postby Brandoe91 » Fri Jan 20, 2012 7:30 pm
I gave it to a good mechanic friend of mine to look at, hopefully he finds the fault or faults . He is also going to smoke the engine to check for leaks.
1gSE wrote:I would. But before that, I would run a can of SeaFoam through it to pin the leak just in case its coming from somewhere else
Brandoe91
Re: Obx Header leak
Postby Eye8Pussies » Sun Jan 22, 2012 3:32 pm
I agree.
having a BIG leak in the header area can throw codes. But with such a small leak (if as indicated by the soot, it is very doubtful that it will throw a code. Vacuum leaks are a lot more sensitive than exhaust leaks
Re: Obx Header leak
Postby SirThomas88 » Tue Jan 31, 2012 11:32 pm
I would say a leak right there at the header could definitely suck in enough air to throw a code.
But try the Seafoam trick to find the leak. Also, the EGR pipes DO break off a lot (mine did) as was previously mentioned.
Replace that gasket ASAP!
SirThomas88
Re: Obx Header leak
Postby Brandoe91 » Thu Feb 02, 2012 6:49 pm
Mechanic fixed the exhaust leak and replace a header stud. After all that, codes P0171, P0300 P303 and P305 all came back. Last night I was reading how some injen intake can throw a P0171.So, this morning I decided to put back the stock intake. It worked, the CEL went away and fuel trims came back within spec. Thanks everyone for all the input. Fingers still crossed but hope I solved the issue.
Brandoe91
Re: Obx Header leak
Postby trd4life » Thu Feb 02, 2012 8:41 pm
injen intake needs to be tuned on a dyno with a safc to work correctly
Re: Obx Header leak
Postby Brandoe91 » Thu Feb 02, 2012 9:11 pm
So it seems. I saw that a few s/ced ppl got the too lean p0171 code but never saw any threads with N/A ppl having any trouble with the injen sri. What's crazy Gabe, Adam was just down here and was gonna do my s/c install but because of the codes we postponed it. Right after he left I fixed the the dam CEL.
trd4life wrote:injen intake needs to be tuned on a dyno with a safc to work correctly
Brandoe91
Users browsing this forum: No registered users and 79 guests
