SolaraGuy.com • View topic - New GLP 1mz-fe cold air extension complete PICS and VIDS
Postby trd4life » Tue Apr 03, 2012 6:26 pm
Finished the prototype today. I still need to weld a mounting tab on the side of the extension other than that its done and is currently running on my 99 solara se v6 5 speed. , this is a custom made extension specifically for a 99-03 solara v6, and should also fit the 97-01 camry v6.
Before we started Stock air box 99 Solara SE V6
Removing OEM parts prepping for Injen short ram w/ GLP Motorsports cold air extesion.
OEM airbox and OEM intake snorkel in fender removed, battery temp. removed, injen intake installed, loosening up fuse box to allow clearance for extension install
Installing extension, there is a bracket coming off the bumper cover than connects to the frame, disconnect that bracket at the frame and pull the bracket out of the way, this will allow you to slide the extension down into the fender. The extension is tough to get down in the fender without moving the bumper cover bracket.
Extension in place
Extension bolted up to injen , battery put back in, fuse box bolted back up.
Before Vid
http://www.youtube.com/watch?v=odaWPPym ... ature=plcp
After Vid with cold air extension
http://www.youtube.com/watch?v=jn5BV0h_ ... ature=plcp
roll on
http://s127.photobucket.com/albums/p133 ... deo003.mp4
Re: New GLP 1mz-fe cold air extension complete PICS and VIDS
Postby thenewguy » Tue Apr 03, 2012 6:54 pm
Sick! I can't wait for mine to come in.. I'm throwing that thing on the day I get it ha
thenewguy
Postby tooshorty » Tue Apr 03, 2012 10:47 pm
dang man, i wish we did this like a month ago so I could have it installed for HIN coming out the 14th...either way, i've been wanting one for four years and you're about to fill in the void for me!
Valley of the SUN!!!!
tooshorty
Postby parkc96 » Wed Apr 04, 2012 2:07 pm
So when is the one for the 4 cylinders coming out? :lol:
2000 camry 4 cylinder: rims, tint, spoiler, head unit, partially debadged, custom catback, custom grille... more to come.
parkc96
Postby Akfahad » Wed Apr 04, 2012 4:38 pm
Nice upgrade! Glad there's another vendor now!
Postby sk8r776 » Fri Apr 06, 2012 9:38 pm
I realize the intake moves back behind the stock fog light location. This does not mean removal of the fog light correct? (Permanently I mean.)
'93 Civic LX --> '02 Accord SE 5-Speed --> '01 Solara SE 5-Speed --> '06 350z Base Rev-UP
Mods
Hid Conversion 8K + 3K, Injen SRI, GLP CAI extension, Lots more to come.
sk8r776
Postby ThatVietGuy » Sat Apr 07, 2012 1:27 pm
It doesn't extend that far down.
ThatVietGuy
Postby tooshorty » Sat Apr 07, 2012 3:24 pm
just make sure you don't go splashing into massive puddles! :roll:
tooshorty
Postby 1gSE » Sat Apr 07, 2012 4:44 pm
tooshorty wrote:just make sure you don't go splashing into massive puddles! :roll:
I've splashed through some massive puddles...... :P
http://www.facebook.com/video/video.php ... 6589160655
Solara-M62 @ 5.5psi
1gSE
Postby pwizzle » Sun Apr 08, 2012 11:06 am
You missed the oncoming car with the splash.
"To be is to do" - Plato
"To do is to be" - Sartre
"Do be do be do" - Sinatra
pwizzle
Postby dinoxor » Wed Apr 11, 2012 7:52 pm
Yeah I was wondering about that.
It extends behind our fog lights
so wouldn't you need a shield of some sort?
or do you just avoid puddles
and yeah from the previous post would you be required to remove your fog lights?
dinoxor
Postby 1gSE » Wed Apr 11, 2012 8:41 pm
Let me put it this way....if you're driving in water deep enough to submerge the filter, you deserve to hydro-lock the engine.
There's a tutorial of the install. And I installed mine without removing the foglight, fender or the fuse box. It's not fun, but it's possible
Solara-M62 @ 5.5psi
1gSE
Postby ThatVietGuy » Wed Apr 11, 2012 9:12 pm
IIRC, the filter sits in the fender at a point a little below the level of the HEADLIGHT, not the fog light.
ThatVietGuy
Postby dinoxor » Thu Apr 12, 2012 12:47 am
Ah, thank you guys for the clarification
dinoxor
Postby hskrsolara » Fri Apr 13, 2012 9:59 pm
sk8r776 wrote:I realize the intake moves back behind the stock fog light location. This does not mean removal of the fog light correct? (Permanently I mean.)
Search "upfd extension". this extension is a great mod and you guys are very lucky that gabe is willing to build a batch. Take the fog light out? Not sure what you've been reading. The filter sits directly behind the headlight, protected from water by the fender liner, directly under the engine bay fuse box. You would have to cross a river to need to worry about taking in water. Should be good, as long as you have a fender liner in. Even without a fender liner, you would still have to be in DEEP water, and sitting still, to hurt the motor.
hskrsolara
