SolaraGuy.com • View topic - GReddy eManage for 1MZFEs
Postby S.Z.-Alpha » Sun Apr 15, 2012 3:31 pm
I heard that you can tune with GReddy's eManage. How does this work and can you tune N/A as well or is it only for people who wanna boost? There's always changing our injectors right>
2000 Toyota Solara a.k.a "Goldie" SLE V6 //PARTS: TRD Muffler w/ Stock pipes, K&N filter, Tokico Blue Shocks w/ Stock Springs, Kenwood H/U with x4 JVC speakers(250x2 Front and 290x2 Rear) w/ JL 1000 watt amp.
S.Z.-Alpha
Re: GReddy eManage for 1MZFEs
Postby 1gSE » Sun Apr 15, 2012 4:19 pm
Unless you're boosted, don't waste your money.
Solara-M62 @ 5.5psi
1gSE
Postby S.Z.-Alpha » Sun Apr 15, 2012 11:08 pm
Ah...I see. Thanks
S.Z.-Alpha
Postby chullen1 » Tue Apr 17, 2012 10:55 pm
I disagree as I am tuning my car on emanage even though I am only doing a full N/A build. I want to be able to have the best tune possible compared to the stock ecu since I am going to be running higher compression. I think it just matters on what you are installing the emanage on. If you are doing on a stock motor it is not needed but if you are building the motor and want to raise rev limit this is a good option.
chullen1
Postby 1gSE » Wed Apr 18, 2012 4:08 am
chullen1 wrote:If you are doing on a stock motor it is not needed
I based my opinion solely off his signature, but I agree with you on a built engine
Solara-M62 @ 5.5psi
1gSE
Postby SirThomas88 » Thu May 17, 2012 10:43 pm
I wouldn't get the eManage unless you go boost. or go for something cheaper like the AEM FIC.
SirThomas88
Postby chullen1 » Sun Jun 03, 2012 10:00 pm
SirThomas88 wrote:I wouldn't get the eManage unless you go boost. or go for something cheaper like the AEM FIC.
I paid $400 bucks for my emanage ultimate, for that price and it came with a harness and everything. I couldn't say "no".
chullen1
Postby SirThomas88 » Sat Jun 09, 2012 11:04 pm
Yea I paid $425 for my eManage Ultimate w/ all the harnesses too, but I still wouldn't have spent that much on tuning software for an n/a car w/ stock engine.
SirThomas88
Postby chullen1 » Mon Jun 11, 2012 8:59 pm
Yeah but the engine gabe and I are building won't be stock so for my purposes it will work just fine
chullen1
Postby SirThomas88 » Tue Jun 12, 2012 12:35 am
chullen1 wrote:Yeah but the engine gabe and I are building won't be stock so for my purposes it will work just fine
I was referring to a stock engine that I assume the OP has. I have no doubt it would be a great benefit to the engine ur building.
SirThomas88
Postby chullen1 » Tue Jun 12, 2012 6:50 am
yeah for sure its not needed on a stock motor but when you are adding a lot of different components like I am, I need the best tune possible.
chullen1
Users browsing this forum: Google [Bot] and 51 guests
