SolaraGuy.com • View topic - Help on rim offset
Help on rim offset
Help on rim offset
Postby Akfahad » Thu Jun 07, 2012 4:43 pm
Disregard the width of the rims I'm going to get, I'm prepared to do minor body work. Just not sure which offset would better.
The front are 19x8.5 that come in either +15 or +38
The rear are 19x10 that come in either +20 or +42
I'm planning on using 235/35/19 series tires all around, which offset would you use?
Re: Help on rim offset
Postby ToyoSolV6 » Thu Jun 07, 2012 10:56 pm
Lowest offset 20 on the rear for sure. with the 42 offset u might run into issues with the wheel hitting ur coilover. U will need body work done to pull the rear quarter panel. The fronts u can get away with the 38 but the lower offset would be nice it will give u enough room to play around in there.
Postby Akfahad » Fri Jun 08, 2012 4:51 am
that's perfect, thank you!
Postby ToyoSolV6 » Fri Jun 08, 2012 7:20 am
No problem!
