SolaraGuy.com • View topic - RIP: Toyosolv6's 1mz-fe
Postby ToyoSolV6 » Thu Jul 12, 2012 3:31 pm
On Monday night my motor finally went out. Had its last race against a fox body 5.0 stang. (i still won) lol Didnt blow when i was racing him it took a crap as soon as i got home. Start puffing blue smoke at idle. I popped the hood and i had a lake of oil everywhere in the engine bay. The dipstick only showed oil at the very tip. And by tuesday morning it didnt start.
So the journey begins. Ill keep you guys posted.
Re: RIP: Toyosolv6's 1mz-fe
Postby 1gSE » Thu Jul 12, 2012 3:38 pm
Come on man, if you're gonna blow it up, you gotta make it dramatic....like spraying a 150 dry shot or a piston coming through the hood lol. Is your other one ready to drop in?
Solara-M62 @ 5.5psi
1gSE
Postby ToyoSolV6 » Thu Jul 12, 2012 4:01 pm
1gSE wrote:Come on man, if you're gonna blow it up, you gotta make it dramatic....like spraying a 150 dry shot or a piston coming through the hood lol. Is your other one ready to drop in?
Lol, i didnt want it to get that bad lol. haha.
And no not yet, still have to replace headgaskets And i gotta put my ARP head studs and few pieces off my engine that will need to be replaced. It will take a while before shes out on the road, i wanna say maybe till the end of august.
Postby Akfahad » Thu Jul 12, 2012 4:07 pm
Sounds like we're both having bad luck...lol
Postby pwizzle » Thu Jul 12, 2012 4:10 pm
So tempted to insert a quote from the first fast and the furious.
"To be is to do" - Plato
"To do is to be" - Sartre
"Do be do be do" - Sinatra
pwizzle
Postby ToyoSolV6 » Thu Jul 12, 2012 4:38 pm
Akfahad wrote:Sounds like we're both having bad luck...lol
lol youre right man!
pwizzle wrote:So tempted to insert a quote from the first fast and the furious.
what quote?
Postby mig0s » Thu Jul 12, 2012 5:09 pm
Change the transmission, rebuild the chassis and drive train and put a fking 2jz in it and twin turbo it?
mig0s
Postby 1gSE » Thu Jul 12, 2012 5:14 pm
Now me and the mad scientist......
Solara-M62 @ 5.5psi
1gSE
Postby yaddadaimsayin » Mon Jul 16, 2012 4:07 pm
"you almost had me? you never even had your car!"
Postby ToyoSolV6 » Mon Jul 16, 2012 5:24 pm
Well i bought the engine from greg the day after mine went out. I took the heads off and noticed one of the cylinders was pitted and cratered. So i cant use it unless i re sleeve the block. i went through 2 performance machine shops one of them quoted me 800 for the re sleeving :( and another shop which seemed to be a little more knowledgeable on what they were talking about told me i have to use a dry sleeve and they carry a brand called Darton. The infiniti/nissan crow uses them and the honda people too. So he told me resleeving an aluminum block is going to be expensive. He said i will be better off boring it and getting larger pistons. So im not financially ready to do something that major on my car yet. So he told me to take out my old motor tear it apart and see how the block looks. He doesnt think my block will be bad. He believes its only the piston rings that went out and that caused the damage. He then said he hone my block out do their full service:
Honing
deck resurfacing
block hot tanking
also change the bearings
they are also going to micro blast it and give that "new" look again
To the heads they will pretty much resurface the heads inspect the valves
and change a few things there too, check for any cracks or leaks and also micro blast it.
I beleive all this should be just under 1k. Their also going to help me source a thicker headgasket so i dont have to run into the high compression issue.
A lot of work, and money thats making me broke. I will probably put my corolla up for sale till this car gets back on the road. I might sell a few parts. im not too sure. Wheels/ coilovers. I dont know yet though.
Postby Mr_Krispy1183 » Fri Jul 20, 2012 11:40 am
I'll buy my corners back if that helps, lol
Postby ToyoSolV6 » Fri Jul 20, 2012 2:45 pm
lol, nah i need to use those lol
Postby ToyoSolV6 » Thu Aug 02, 2012 12:38 pm
I now have ARP head studs. MLS Metal headgaskets. Motor is coming out hopefully by next week. I got a quote for 1800 at TG's Performance about 20 Minutes from my house.
Boring the block
Decking the block
Polished Crank
Reconditioning connecting rods
over sized anodized pistons
Freeze plug kit
Main bearings
Rod bearings
Heads
3 angle valve job
Resurface
valve adjustment
Micro blast heads and block
assembly of short block
pretty much thats it.
Postby DSM_Lara » Thu Aug 02, 2012 3:04 pm
Is this the first time your pulling your whole block to get a rebuilt??? In other words is that your original block that was from the car.
DSM_Lara
Postby ToyoSolV6 » Thu Aug 02, 2012 4:03 pm
yeah same block! it served me well bro i cant let this engine go to waste it was a strong engine from the beginning. Just the fact that it almost hit 290whp on only 5.5psi. At the time i was dynoed there was a few only hitting 260.
