SolaraGuy.com • View topic - Flushing out the wheels?
Postby PlateLunch » Sun Oct 21, 2012 11:17 am
Hey guys, I was just wondering if it would look awkward to throw some spacers to flush out the wheels even though I have a gap from being only on Teins/Tokicos, not coilovers? AND, do I need to put the same size on all four wheels or can I go a bit lower in front, as it looks like the fender pokes out a little less? I have 18x8 et40 on with some 225/40/18's for reference.
Thanks for the help!
PlateLunch
Re: Flushing out the wheels?
Postby DSM_Lara » Sun Oct 21, 2012 2:53 pm
Be prepared for the rears to rub. 20mm Spacers for the rear will do.
DSM_Lara
Postby Bostonlara » Sun Oct 21, 2012 4:38 pm
DSM_Lara wrote:Be prepared for the rears to rub. 20mm Spacers for the rear will do.
are you running spacers on yours? i just got the TRD rims, the fronts are flusher in the front and pushed out a little more than the stockies in the rear. i have a 42 offset with e 17x7's
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Postby PlateLunch » Sun Oct 21, 2012 6:00 pm
20's in the rear, rajah. Would a fender roll take care of the rubbing? Thanks! :D
PlateLunch
Postby Akfahad » Tue Oct 23, 2012 8:19 am
^^yes
Postby PlateLunch » Wed Oct 24, 2012 6:22 pm
Thanks! Your set up is TIGHT by the way, that is what I am eventually heading for :D What are the specs if you don't mind dropping the knowledge?
PlateLunch
