SolaraGuy.com • View topic - Toyosolv6's Build thread
Re: Toyosolv6's Build thread
Postby ToyoSolV6 » Wed Mar 27, 2013 10:47 am
Smaay wrote:why did you go cheap on those ebay gasket kits. you really should have gotten the OEM kit. countless times i have run into issues where the ebay kits dont fit, or the gaskets just leak
Really? Well the only gaskets im using off of this are the intake manifold gaskets the exhaust gaskets and the valve cover gaskets anything else thats vital ill be ordering OEM. I got it because it was super cheap. Either way the good stuff i got OEM, Timing belt, water pump, oil pump, pulley tensioner, Head gaskets etc..
Postby Smaay » Thu Mar 28, 2013 3:07 pm
i hope they work out for you.
1990 Celica All-Trac 3S-GTE
1997 Celica GT 1MZ/3MZ hybrid
1997 Supra 2JZ-GTE
2001 Celica GT-S 2ZZ-GTE
1998 Dodge Ram Cummins Turbo Diesel
Thats alot of BOOST!!!!
Smaay
Postby ToyoSolV6 » Thu Mar 28, 2013 3:44 pm
Smaay wrote:i hope they work out for you.
Lol so do i man, you just scared the crap outta me tho lol. I might have to look into again.
Postby ToyoSolV6 » Tue Apr 02, 2013 2:00 pm
Engine is currently being balanced.
By next week it should be back home and then i get to work. By next friday i will have 3 weeks to work on her before toyotafest and i finish exactly in two weeks that will drop me at the 3rd of may and the show is on the 4th still dont know if i will make it. Due to there will still be minor bugs here and there to solve
Postby ToyoSolV6 » Mon Apr 15, 2013 3:43 pm
Engine is done, picking it up in an hour! so stoked! ill post pictures when i get a chance! :)
Postby DSM_Lara » Mon Apr 15, 2013 5:02 pm
She will live soon once again. Very Exciting. :drinking:
DSM_Lara
Postby GzNutz » Tue Apr 16, 2013 2:14 pm
Can't wait to see how it turned out.
Postby ToyoSolV6 » Thu Apr 18, 2013 3:13 pm
DSM_Lara wrote:She will live soon once again. Very Exciting. :drinking:
Yes she will soon shell be whining again :)
GzNutz wrote:Can't wait to see how it turned out.
Thanks man! :)
UPDATE:
Block is currently being worked on by my buddy and I i have pics in DSLR ill post up later. I only had monday night to work on it so we installed the oil pump assembly and i decided to throw on my ARP studs since it looked nice haha. Today im going again to finsh getting the bottom end put together. This weekend were jumping on the porting for the heads if all goes as planned and the heads are done by monday. Then the engine should be getting dropped back in next week and then its all about hooking things up and what not.
I still got little minor issues i need to take care of first. I still need a clutch i need iridium plugs i need to get my NRG short hub for my new steering wheel. I need to replace the boots on my axles and one of the bolts on the plates for the S/C stripped so i have to go out and find one of those.
Postby PlateLunch » Thu Apr 18, 2013 7:32 pm
I have three new black ones i'll throw in with that power steering pump, and i'm pretty sure I have an alternator if you need one too.
PlateLunch
Postby ToyoSolV6 » Fri Apr 19, 2013 9:29 am
^Well the one i need is the bolt that runs through the dogbone and through the s/c plates. Is this the same length?
Postby PlateLunch » Fri Apr 19, 2013 11:16 am
Ah, no these are for the idler pulleys. Try these guys for that long bolt http://www.mcmaster.com/#
PlateLunch
Postby thenewguy » Fri Apr 19, 2013 3:16 pm
Silicon Boots!!!
thenewguy
Postby SirThomas88 » Sat Apr 20, 2013 6:23 am
Can't wait to see your project completed! It's a shame you're all the way on the other side of the country. Wish I could go to Toyotafest! :cry:
SirThomas88
Postby ToyoSolV6 » Mon Apr 22, 2013 3:50 pm
PlateLunch wrote:Ah, no these are for the idler pulleys. Try these guys for that long bolt http://www.mcmaster.com/#
oh nice, thanks for the link!
thenewguy wrote:Silicon Boots!!!
Dude! where can i get silicone boots from??
SirThomas88 wrote:Can't wait to see your project completed! It's a shame you're all the way on the other side of the country. Wish I could go to Toyotafest! :cry:
Thanks man! yep ur right wish all of us were a little closer to each other lol. We can all have a friendly run hahah :)
Postby GzNutz » Wed Apr 24, 2013 7:57 pm
I know it's only been two days but how about an update! :)
