SolaraGuy.com • View topic - breather filter?
breather filter?
breather filter?
Postby dinoxor » Sat Nov 17, 2012 1:16 pm
Lately my check engine light is turning on more and more frequently as I rev my engine to high rpm.
But, due to budget, I could not afford to make an oil catch can at the moment but rather resolved to a more temporary solution until funding is sufficient.
I installed a 12mm breather filter
However, this is how my set-up looks like.
Are there any drawbacks to this setup?
I know eventually the filter is going to drip oil but I placed it in a location where the oil will (hopefully) have the least effect on the engine.
Any input will be great.
Thanks!
dinoxor
Re: breather filter?
Postby Bostonlara » Sat Nov 17, 2012 11:50 pm
what codes?
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Postby dinoxor » Sun Nov 18, 2012 12:45 pm
P0171
I should have mentioned this thread is a continuation from my last thread here:
viewtopic.php?f=2&t=53939
dinoxor
Postby ToyoSolV6 » Mon Nov 19, 2012 1:07 pm
Thats better than having oil drenching the maf, other wise oil coming out of there means worn piston rings, prepare yourself for a rebuild in the next few years.
Postby dinoxor » Tue Nov 20, 2012 12:02 am
Sweet thanks for the heads up!
dinoxor
Postby SirThomas88 » Tue Nov 27, 2012 10:09 am
The drawback is that your blow-by is not being sucked out. Shouldn't really be a problem. But having your blow-by actively sucked out is preferable to it building up in pressure and evacuating itself.
I got my oil-air separator from JEGS for less than $50.
http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Air-Oil-Separator/763433/10002/-1
Check it out!
BTW, I believe there are TWO blow-by evacuation ports (or whatever the heck they're called). I have my oil-air separator hooked up to two vacuum lines coming off the engine. One in the front as shown in your picture, and one that comes from the back head.
SirThomas88
Postby SirThomas88 » Tue Nov 27, 2012 10:17 am
SirThomas88
Postby PlateLunch » Tue Nov 27, 2012 11:31 am
^^^Nice! Do you find that the one on the PCV line affects your S/C performance at all!
PlateLunch
Users browsing this forum: No registered users and 102 guests
