SolaraGuy.com • View topic - climate control questions
Postby wizzy » Wed Feb 06, 2013 5:47 pm
hey i have a simple question do the 2000 solaras climate controls have lights because it gets really dark in my car and i can hardly see the controls at night and do it have a bulb in the ashtray ? thanks
2000 Toyota Solara SE V6
10k Hid Fog's and Headlights
Black Coners
2010 Camry Bars
Basically stock (For Now)
wizzy
Re: climate control questions
Postby 2Gud2BTru » Wed Feb 06, 2013 7:28 pm
They should. Do you have the manual controls or the automatic ones? By manual I mean the ones with the red and blue for the temp. I have the auto controls and the whole thing lights up. No light in the ashtray but there should be a light for the ring around the plug next to the ashtray. If it isn't lighting up, try twisting the knob on the left side of the steering wheel above the little pop out tray. It should be behind the light lever on the steering column. If that doesn't work, its either the bulbs are burnt out or the fuses are blown. I may be wrong but that's what I think.
-01' SLE v6 coupe:Traded in. 223k
-06' Accord Coupe 4banger: DD
2Gud2BTru
Postby wizzy » Wed Feb 06, 2013 8:30 pm
yea i have manual ones and the dimmer is always up the red and blue do not light up at night so don't the rest on the climate controls any chance you know where the fuse is ? is it in the coin holder under "HEAT" ?
Black Coners
2010 Camry Bars
wizzy
Postby Bostonlara » Wed Feb 06, 2013 10:00 pm
Might just be a bulb, if it were the fuse all the lights would be out on the hvac controls. And yes the ashtray should have a bulb. It's common they burn out
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Postby wizzy » Thu Feb 07, 2013 12:51 am
thanks for the help guys
Black Coners
2010 Camry Bars
wizzy
Postby 2Gud2BTru » Thu Feb 07, 2013 7:27 am
Bostonlara is right. Time to pull that sucker off and replace some bulbs! I didn't know the ashtray has a light. Where is the bulb located? I always thought it didn't. Must be because mine burnt out a long time ago.
2Gud2BTru
Postby Solarasian » Thu Feb 07, 2013 1:15 pm
lol when are us new englanders going to have a meet? =D
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Kaminari Lip Kit(stand by)
Tokico hp Struts
Tein S Tech
Solarasian
Postby wizzy » Fri Feb 08, 2013 2:28 pm
lol im down
Black Coners
2010 Camry Bars
wizzy
Users browsing this forum: No registered users and 84 guests
