SolaraGuy.com • View topic - SW20 TRD LSD - CLUTCH TYPE
Postby HARKEM » Wed Nov 26, 2014 3:09 am
Has anyone fitted a SW20 TRD LSD - Clutch type into a camry E153???
I've just got my hands on one and need some help? am a little confused with some of the post's..
Would you be willing to write a quick guide or "how to" on what you need to do to make it fit in??
2001 V6 CAMRY TOURING
DBA 4000 Slotted/Cross Drilled Rotors Front/Rear, EXEDY Stage 1 Race Clutch, FIDANZA 9lbs Flywheel,
Whiteline RSB & FSB, TRD Suspension, CUSTOM Headers&OBX CatBack, TRD S/C:)
HARKEM
Re: SW20 TRD LSD - CLUTCH TYPE
Postby Gregtrd » Thu Nov 27, 2014 10:52 am
The kaaz Lsd I've installed on my camry and like 5 others are from and mr2. Parts you'll need is 16 final gear bolt, speedo wheel for your speed sensor, speed ring and snap clip, and right and left bearing. Do you have a picture of the Lsd, these are the parts I used when I got brand new lsd. If you have a used on those parts might be on there already.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby HARKEM » Thu Nov 27, 2014 1:29 pm
Here's the lsd i bought: http://www.ebay.com/itm/361120880220?_t ... EBIDX%3AIT
Do i have to do anything about my axle stubs?
And are these some of the parts?
trd4life wrote:Driven Gear, Speedometer 33481-12100
Ring, Snap 90520-99011
Bolt, Washer Base: 90105-12150 x16 (bolts for drive gear)
If i have the lsd sent to you Greg, would you be willing to set it up for me?
want to put a new set of clutch pads in it as well but i can do that if you want..
HARKEM
Postby Gregtrd » Thu Dec 11, 2014 3:14 pm
I was told by Ray from kaaz Usa that lsd should be a straight drop in.
Gregtrd
Postby HARKEM » Sun Jan 11, 2015 6:34 am
Sweet!!
Thanks Greg!
I get it shipped to me soon so i'll have it in a few months, have a spare M/T so I might practice on that first :)
HARKEM
Users browsing this forum: No registered users and 139 guests
