SolaraGuy.com • View topic - Upgraded Solara Fuel Injectors
Postby flybigjet » Mon Sep 29, 2003 2:49 pm
For those of you who've upgraded your stock 1MZ-FE Solara injectors, a question-- I *think* I've found the right ones, but a little confirmation would be nice.
2JZ-GE motor
'93-'98 Non-Turbo Supra
Injector Type: Saturated
Factory Flow Rate: 315cc
Feed Type: Top
Am I in the ballpark? Also, is this a simple plug and play, or will I have to rewire the harness? I'm assuming (hoping?) just plug these in and redyno to adjust the S-AFC.
Thanks. Rod.
flybigjet
Postby EricSol » Mon Sep 29, 2003 4:34 pm
They are plug and play. Set your low map with a obd2 scanner and your high map on the dyno.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby Mole » Mon Sep 29, 2003 4:48 pm
i thought the flow rate is 295cc. for 2jz
they just pop right in. might want to get new seals with them though.
Postby flybigjet » Mon Sep 29, 2003 5:59 pm
TRDMole177 wrote:i thought the flow rate is 295cc. for 2jz
The web sites I saw today listed them at 315cc.
http://www.lightningmotorsports.com/techinjector.htm
And why would I want to get new seals for new injectors?
Thought I was over the Solara, and now I'm getting ready to drop another 5 grand. Yikes!
Thanks. Rod.
flybigjet
Postby Mole » Mon Sep 29, 2003 6:52 pm
you'd want to get the new seals, just so that they do not leak. there is a little bit difference in appearance if you were to line up the two. last i recall the 2jz are a little bit longer than the 1mz.
the guy who did the injector install mainly works on MKIII/IV supras,but works on toyota engines overall, so i'd rather take his word rather than the website you provided.
Postby flybigjet » Mon Sep 29, 2003 7:36 pm
Just for clarity; you mean that you need new *Solara specific* injector seals, not Supra seals.
Next question. Any idea where to find said part seals? Can I get them seperately from a dealer, or are they only packaged with injectors?
Thanks. Rod.
flybigjet
Postby Pat S » Mon Sep 29, 2003 7:59 pm
Rod,
Why the big injectors? You can't possibly being running lean up here are you?
Pat S
Postby flybigjet » Mon Sep 29, 2003 8:18 pm
Preventative actions. If I'm going to upgrade the intake/exhuast (yet AGAIN!) and heads, I'd like to get the injector duty cycle down a bit before I get too creative on the dyno. R.
flybigjet
