SolaraGuy.com • View topic - speakers wont work
speakers wont work
speakers wont work
Postby Airwalk1421 » Wed Oct 01, 2003 1:06 pm
I recently tried to install my amp and attached the remote wire to the red wire on the back of the stock deck.. now the stereo comes on but the speakers just crackle. Any suggestions?
Airwalk1421
Postby Airwalk1421 » Wed Oct 01, 2003 1:51 pm
I just turned on the radio and music came on for about 2 sec then it went out again. Can someone please help?
Airwalk1421
Postby Airwalk1421 » Wed Oct 01, 2003 2:12 pm
They work now.. think it had to do with battery resetting.
Airwalk1421
Postby geminimouse » Wed Oct 01, 2003 2:12 pm
bad ground..maybe
posted at the same time :) . As long as it's working
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Airwalk1421 » Wed Oct 01, 2003 7:46 pm
Its the strangest thing cause the speakers work and then they start cutting out after like 20-30 min of use. The amp isnt installed.. all the wires were disconnected. Anyone know what could be happening??
Airwalk1421
Postby indiglosolara » Wed Oct 01, 2003 11:06 pm
your problem might be becuz you are running the remote to your constant 12 volt. you mite wanna try a diff remote selection. your remote wire is taking up too much power from your headunit.
I installed a amp ans sub to my friends IS300 stock headunit and we used the power mirror 12 volt for the remote and it works fine. since the mirror you dont use too much. tap it into the fuse holder section. but becareful you dont wanna blow a fuse.
also by doing it that way you always have the chance of blowing a fuse.
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Airwalk1420 » Thu Oct 02, 2003 3:06 am
No but the turn on wire has been disconnected and all the other amp wires have been too.
Airwalk1420
Users browsing this forum: No registered users and 79 guests
