SolaraGuy.com • View topic - Injectors
Injectors
Injectors
Postby Smitty__16 » Wed Oct 01, 2003 7:54 pm
Would supra injectors help the performance of a non s/c solara? If so how much?
99 Solara V6 auto
Smitty__16
Postby JoeB » Wed Oct 01, 2003 8:16 pm
Smitty, Toyota does a good job of selecting the correct spec fuel injectors. The problem is when you use forced induction, you change the balance of the air fuel mixture. So with forced induction you may need to select a fuel injector that has a higher flow rate to prevent the injectors from operating at too high a duty cycle. We are very fortunate to have several people that post on this forum that know a great deal about the specifics and have recommended a good higher flow injector along with the necessary things that should be done to use them.
Another way to look at it is if you want to upgrade your fuel injectors, you will need to do something to get more air in to the mixture. Supercharger 8) -JoeB
JoeB
Re: Injectors
Postby Mole » Wed Oct 01, 2003 9:53 pm
Smitty__16 wrote:Would supra injectors help the performance of a non s/c solara? If so how much?
to make things short. No.
Users browsing this forum: No registered users and 78 guests
