SolaraGuy.com • View topic - do i need new springs?
Postby Guest » Wed Oct 01, 2003 8:52 pm
Got a quick question. i bought a system and the box is in my trunk and my car is a little lower from the weight, also the rid is harsher, the amps arent even installed yet( fri the work gets done) will buying new springs and strusts fix the harshness of the ride? Also it seems the back is slightly lower than the front
Guest
Postby onefiend » Wed Oct 01, 2003 9:20 pm
thats normal, the back will drop a bit because of the added weight
onefiend
Postby boneezy » Wed Oct 01, 2003 9:50 pm
theres no real compromise for the rear tuck from the added weight and ride comfortability... its one or the other...
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby HKSV6SLE » Thu Oct 02, 2003 11:04 am
it won't do much since your adding weight to the back your car no matter what is gonna settle down a little bit...when i took one of my amps and my box out....for servicing....my car went up about half an inch...so...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby WTF?? » Thu Oct 02, 2003 2:16 pm
Retired... its been fun Image
WTF??
