SolaraGuy.com • View topic - Solara Altezzas
Solara Altezzas
Solara Altezzas
Postby HydroponiK » Mon Oct 06, 2003 12:45 pm
I've been thinking about purchasing the carbon fiber altezzas for my Solara and I was wondering where would the turn signal output be coming from? On the OEM taillights, the location would be the bottom-outside of the assembly but it doesn't look like there is one on the altezzas. Could someone who has them enlighten me?
HydroponiK
Postby FLASH » Mon Oct 06, 2003 1:41 pm
Well technically it depends on which red circle you put the bulb in...look at my avatar. I have the small red circles in the middle of the taillight as my turn signal and the big circles on the edges as the brake lights.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby TadS » Mon Oct 06, 2003 1:53 pm
The bulbs will only go in certain holes on the Altezzas. There is a slightly different pattern on the plugs, so the way Flash says his work is the only way the bulbs “should” go. I am pretty sure mine are that way also.
TadS
