SolaraGuy.com • View topic - Help on wiring up air/fuel ratio guage
Postby solara blues » Thu Oct 09, 2003 6:27 pm
Just got the guages and I am wondering which of the 4 wires on the O2 sensor I should use for the air/fuel guage. Does anybody know?
always looking for more cool stuff
00 Solara v6 5 speed
Still Not Fast Enough!
solara blues
Postby Turbosolara » Thu Oct 09, 2003 11:17 pm
tape it onto the blue wire on the O2 sensor
Postby solara blues » Fri Oct 10, 2003 5:30 am
Is the sensor wires same colors on the 2.2l and the v6 3.0?
solara blues
Postby Guest » Fri Oct 10, 2003 10:50 am
tap the black wire... i just did it about 2 weeks ago
Guest
Postby Guest » Fri Oct 10, 2003 10:56 am
i drive a v6 and i tapped the black
Guest
o2 sensor
Postby solara blues » Fri Oct 10, 2003 12:34 pm
There are 4 wires. I think 2 are grounds, 1 signal, and 1 heater. The colors are 2 blacks, 1 white and 1 blue. It should be white or blue I think, but I'm not sure.
solara blues
Postby Guest » Sat Oct 11, 2003 8:42 am
ill reiterate my prevous statement, there is one black wire and it is the only wire which will give you a signal. When i did this about 2 weeks ago i originally tapped the incorrect wire, however the way i tapped it was using a t splice so theres no harm done. good luck
Guest
Postby Turbosolara » Mon Oct 13, 2003 12:32 am
lol, everyone all tape on different wires. so which one did you tape it onto anyway?
Postby Yanks0114 » Wed Nov 05, 2003 9:28 am
Did we ever figure this out?
I am still having trouble on my A/F gauge. I tried both blue and white.
I think tapping the black on is incorrect
Postby solara blues » Wed Nov 05, 2003 9:59 am
I ended up hooking it up to my yellow/red wire on the other side of the plug where O2 sensor wires plug in. All my gauge shows is stoich when I am letting go of the gas pedal, and rich when I gas it up. If thats what it supposed to show, let me know.
solara blues
Postby Yanks0114 » Wed Nov 05, 2003 10:11 am
Which gauge do you have? If its the autometer gauge, its supposed to dance around(because your A/F mixture is continually changing). Under hard acceloration, your o2 sensors can not deliver the data quick enough so your car relys on the ECU's fuel map, and then the gauge should stay much more constant
a/f guage
Postby solara blues » Wed Nov 05, 2003 1:01 pm
I have a cheap autometer guage, is it working proparly considering what I described it does?
solara blues
Users browsing this forum: No registered users and 79 guests
