SolaraGuy.com • View topic - Getting headlights to turn off
Postby kubi » Sun Oct 19, 2003 7:48 pm
Well I got my alarm installed today and part of the remote start system keeps the car on when you take the key out until you close the door, then once you close the driver's door the car shuts off. Now the problem with this is that my headlights don't automatically turn off since the car is still running. Am I just going to have to manually turn my headlights on and off now or can anyone come up with a way around that?
kubi
Postby impactX » Mon Oct 20, 2003 12:27 am
How hard is it to turn off your headlights before closing the door?
impactX
Postby kubi » Mon Oct 20, 2003 1:05 pm
It's not, but I haven't done it since I got this car since they turn themselves off :) Probably should just do it though so my headlights don't come on when I remote start, heh.
kubi
Postby HKSV6SLE » Mon Oct 20, 2003 1:09 pm
your going to have to maunally turn the lights off.im sure there's a way to program the alarm to do it for you..but im not sure..im working on getting my alarm to pop my trunk open for me...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby krook » Mon Oct 20, 2003 10:23 pm
do you turn on the lights manually when you drive? i don't. the feature you are talking about sounds like the "convenience ignition" feature or somethin' like that. it's where you can leave the car running for a few moments w/o the key in moments when you're gonna just "run in and run out" somewhere...like a convenience store!
i just use it to let my car cool down before i turn it off. and my alarm shuts EVERYTHING off. i didn't have to wire anything to the headlights from the alarm, so maybe that's what the alarm place did to yours. ask them to re-wire it correctly.
krook
Postby kubi » Tue Oct 21, 2003 1:47 am
no, i do not turn my headlights on manually, but i have to now.
anyway, the reason it stays running is to check and make sure the car can be remote started, since it's a manual transmission it has to be sure the car isn't in gear.
anyway i guess i'll check back with the installer, thanks!
kubi
