SolaraGuy.com • View topic - Is this true about the SAFC?
Postby richt1271 » Sat Oct 25, 2003 11:19 am
i was talking to a mr2 driver and he told me that the AFC is just used to trick the ECU. its really just a "engine-killer" or so he calls it.
is this really the case? im not exactly sure.
richt1271
Postby cdssolara » Sat Oct 25, 2003 2:03 pm
I'm not sure about the "engine killer" part, but yes, the S-AFC works by "tricking" the ECU. It alters the air flow signal so that the ECU compensates by attempting to deliver more fuel. It's what's known as a piggyback computer, because it works in conjunction with the ECU, as opposed to "rechipping" the ECU. As far as I know, there are still no chips to modify the 1MZFE engine, or 3MZFE.
AFC stands for Air Flow Converter, by the way.
cdssolara
Re: Is this true about the SAFC?
Postby pro956 » Sat Oct 25, 2003 3:39 pm
richt1271 wrote:i was talking to a mr2 driver and he told me that the AFC is just used to trick the ECU. its really just a "engine-killer" or so he calls it.
my understanding is that it's more of an "engine-saver" if used properly
AIM: pro956
2002 5-speed se v6
pro956
Postby impactX » Sat Oct 25, 2003 7:47 pm
It's just like any other tools in life, you can f00k things up if you don't use them correctly.
impactX
Users browsing this forum: No registered users and 78 guests
