SolaraGuy.com • View topic - Tire Advice
Tire Advice
Tire Advice
Postby TrevDog » Mon Oct 27, 2003 7:25 pm
I have the stock rims on my 2000 Solara and the tread is really getting bald on my summer tires. I don't really want to upgrade to some nicer 17in or 18in rims but I still want them to look cool. So what tires should I buy that would make them look really cool without going with bigger rims?
thanks,
Trev
2000 Silver Solara SLE V6 Auto
Street Glow Blue Line green undercar neon lighting
Street Glow blue neon tubes under seats and red neons in trunk
400watt JBL amp and 10in sub in the trunk
TrevDog
Postby HKSV6SLE » Mon Oct 27, 2003 7:50 pm
uh....your talking bout just getting new tires not thr wheel itself right? cuz if that's the case than anything would be fine..i think the stock tires suck and cost too much and there are cheaper replacements that are just as good or better..
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby impactX » Mon Oct 27, 2003 8:37 pm
I think 205-55-16 looks better than the 60 aspect. It wouldn't throw the speedo/odometer off and you have a lot more choices.
If you want some hardcore dry tires that can almost match the grip of R compound, get the Falken Azenis. If you want good tread wear rating for summer tire, a good ride (due to softer side wall) and extremely well wet + puddle traction (agressive tread pattern), get the Toyo T1-S.
impactX
Postby flybigjet » Wed Oct 29, 2003 6:03 am
215-55-16 look about as good as you're going to get on a 16" wheel- that's what I had before I upgraded to 17's and really liked the look. They're also just about the same as oem and TRD's 17" recommendation, so your speedo will be fine.
Go here to get some sort of idea of what the different sizes will look like on your wheel:
http://www.miata.net/garage/tirecalc.html
Of the tires I had (OEM, Michelin, and Nitto), I'd really recommend the Nitto NT-450's. Excellent performance at a very good price. Wore *much* better than the Michelin's.
One other consideration might be the Sumitomo's HTRZ-II's (if they come in a 16). That's what I have on my 17's and have been very pleased. R.
"Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup."
http://www.cardomain.com/id/flybigjet
flybigjet
Postby Mole » Wed Oct 29, 2003 10:27 am
try bridgestone pole position s-03...
those are my next set... expensive, but highly recommended.
Postby HKSV6SLE » Wed Oct 29, 2003 12:44 pm
i always wanted those tires the bridgestone potenza S03' pole postion's....but i know they cost an arm and a leg each but hey..if you want one of the best tires out there..then...
www.lexusnet.com
HKSV6SLE
I recommend Bridgestone Potenza RE730
Postby nmatthis » Thu Nov 06, 2003 8:59 pm
I have a 99 Solara V6 with the stock 16" wheels. The first set of replacement tires were Toyo Proxes FZ4 215/55-16s. The second set of tires, which I still have, are Bridgestone Potenza RE730 225/55-16. Yep, 225's on stock 16x6 wheels. No rubbing at all and I have the TRD Bilstein struts and TRD springs. I really like the 225 size on these wheels, though this is the absolute widest I'd go. And I really like the RE730's. They grip like you can't believe even in the rain. The only problem is that they're a little loud, but that's the only complaint.
Neal Matthis
DWP 99 Solara SE V6 5-spd
TRD Supercharger (4 psi)
TRD struts/springs
TRD quickshifter
Whiteline RSB
160k+ miles
nmatthis
