SolaraGuy.com • View topic - bend in rim
bend in rim
bend in rim
Postby sto » Mon Nov 17, 2003 12:17 pm
would a bend in the rim cause the tire to fade quickly?? im askin because i swapped my trd rims back to stock for the winter and the passenger front was almost bald, while the others are fine. just wondering if yall know. i am also thinking it is the alignment??? thanks - STO
sto
Re: bend in rim
Postby indiglosolara » Mon Nov 17, 2003 12:20 pm
sto wrote:would a bend in the rim cause the tire to fade quickly?? im askin because i swapped my trd rims back to stock for the winter and the passenger front was almost bald, while the others are fine. just wondering if yall know. i am also thinking it is the alignment??? thanks - STO
it would be the aligment... the bent rim would cause more virbation / rough ride then weird tire ware..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby impactX » Fri Nov 21, 2003 5:54 am
Your differential will wear out faster if that tire is almost bald.
Swap that to the right rear.
impactX
Users browsing this forum: No registered users and 79 guests
