SolaraGuy.com • View topic - o2 snsor problem
o2 snsor problem
o2 snsor problem
Postby agentdpuble07 » Sun Nov 30, 2003 11:53 pm
i was wondering how many people had trouble with their o2 sensor (after the cat). it was going out, then i put on my greddy cat back and it killed the sensor so i changed it out and about a week later im getting the check engine light again. i was wondering if any one else with an exhaust had any problems with the sensors or what i should do
agentdpuble07
Postby Turbosolara » Mon Dec 01, 2003 12:19 am
when the check engine light on (A/F sensor malfunction) sometime it might just indicate your car runs too lean or too rich. are you at california? if so, you should have another one at the exhaust maniford.
Postby agentdpuble07 » Fri Dec 12, 2003 8:51 am
im in tx and i dont know where i can get an 02 sensor simulator. i think i might need one. i have a greddy exhaust and i think thats y the indicator is coming on.
agentdpuble07
Postby agentdpuble07 » Fri Dec 12, 2003 8:52 am
agentdpuble07
Postby Mole » Fri Dec 12, 2003 10:59 am
the greddy should not kill the sensor. are you force inducted? there may be an other problem
o2 sensor
Postby super_PeNiS » Tue Dec 16, 2003 2:31 am
my o2 sensor also went out. the o2 sensor that is after the cat. I also have a greddy , but i dont think its the greddy because i stripped the o2's screw and its loose rite now. I went to an auto shop to see how much it would cost to replace the o2 sensor. OEM would cost $129 and bosch 02 sensor would cost $89. i think u can find some online also.
damn iraq
super_PeNiS
Postby xyntax » Tue Dec 16, 2003 12:23 pm
Naive Q for this thread: Would an A/F ratio gauge installed help determine the problem?
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby agentdpuble07 » Wed Dec 17, 2003 9:21 am
i have a short ram but it never did anything to the sensor til now. i replaced the sensor once already but now i have to do it again? i have no other upgrades other than the exhaust and the intake. would the a\f guage help
agentdpuble07
Postby Mole » Wed Dec 17, 2003 10:22 am
a/f can tell you if you are running lean or rich. the gauge by autometer does not handle that job. it just sits there and looks pretty. the a/f gauge by greddy is accurate at all levels, but its pricey.
or the SAFC II has a monitor to see if the car is knocking. if you do, then you may be running lean thus blowing the sensors.
Postby JoeB » Wed Dec 17, 2003 11:54 am
I agree, you get what you pay for with an air/fuel gauge. They can be very useful especially if you are constantly modding your car or if you have it dialed in close to limits. I think that goes for all of us with forced induction. Until the fuel system upgrade from Gadget/URD was available, we've been running lean on 1 end, rich on the other and many people as a result have blown knock sensors. The big difference in the gauges is narrow band vs. wide band gauges. If you already have a narrow-band air/fuel gauge like those from AutoMeter, one way to make it better is like what I have. I've got the Bosch M-300 Wide-Band oxygen sensor from PLX Devices http://www.plxdevices.com. This has a wide-band O2 sensor that mounts in the exhaust just like when a dyno tune is done. It sends the signal to a digital readout that is accuare to <0.1. From there, they have a wide-band to narrow-band converter so it can also be hooked up to AutoMeter narrow-band gauges. This will make the narrow-band gauge that you already have installed read like a wide-band. Again, this option is pretty expensive > $300. -JoeB
JoeB
Postby agentdpuble07 » Wed Dec 17, 2003 1:09 pm
is the afc thing a monitor for the fuel taken into the engine if so should i get that to control the air and fuel in my car. would that solve the problem
agentdpuble07
Postby paradizecityz » Wed Dec 17, 2003 7:08 pm
I have a 1998 Toyota Camry LE and i put in an intake back then and I get the check engine light, i went to get it Diagnosed and i got the error code P0171, System Too Lean (Bank 1), can someone please tell me what this mean and what I should do to fix this, I heard from my friends to change the O2 sensor but Im not sure if it is correct, someone please help me out and reply
paradizecityz
