SolaraGuy.com • View topic - Upgrade fuel injectors
Postby AT » Tue Dec 02, 2003 3:34 pm
Where can I purchase supra injectors for my Solara? and which do you recommend 1jz or 2jz? is there a big difference between the two injectors?
Also, may need to upgrade fuel pump in gas tank, any suggestions as to which one I should purchase?
Toyota Solara 5spd S/C 6psi pulley.
SAFCII
Greddy Catback Exhaust
Rod Millen Intake
Thanks for your help
AT
Postby JoeB » Tue Dec 02, 2003 3:47 pm
AT, I'm looking into the same thing. I'm talking to some people about it, I'll let you know what I come up with. UltraSlow has done a lot of work in this area. Check out his post and the links he posted about it.
After all the people having trouble with knock sensors when trying to increase boost, I think it'd be better to increase the fuel flow. I'd like to try to go beyond 6psi. -JoeB
JoeB
Postby Mole » Tue Dec 02, 2003 5:15 pm
combined with a air/fuel controller 2jzge injectors are the way to go. their flow rate is 295cc comparing with 1mz's 210cc, which just gives extra breathing space under heavier boost applications.
Postby HKSV6SLE » Tue Dec 02, 2003 8:12 pm
rc engineering..well i think its Rc anyways out here in so. cal does injector work might wann contact them.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby AT » Tue Dec 02, 2003 8:39 pm
Thanks JoeB
AT
