SolaraGuy.com • View topic - Does anyone know where to get fidanza flywheels
Postby richt1271 » Wed Dec 10, 2003 11:43 am
i been searching around online and the only store i found it in did not have it in stock...i was just wondering if some of you that has it in your car knows a place to buy it.
oh and does the solara have the same clutch as a mr2? what year and type and will the flywheel be the same as well? thanks in advance.
richt1271
Postby HKSV6SLE » Wed Dec 10, 2003 2:12 pm
whats that?
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby WTF?? » Wed Dec 10, 2003 2:18 pm
Retired... its been fun Image
WTF??
Postby cdssolara » Thu Dec 11, 2003 12:16 am
I got mine through Terry at grd4spdracing@cox.net. He has a performance shop in the San Diego area, and was trying to put together a group buy for clutches and flywheels about a year and a half ago. If he can't get you one, he may know of someone who can.
I also got a Clutchmasters Stage 2 clutch, and I believe it's the same clutch as for the MR2 Turbo.
cdssolara
Postby Akfahad » Thu Dec 11, 2003 9:12 am
yeah it is the same as the MR2 Turbo. I contacted clutchmasters when i was looking, they'll tell you the same thing. Nice guys by the way
Postby richt1271 » Fri Dec 12, 2003 3:02 am
if the clutch is the same as mr2..then the flywheel is the same as well?
and which year/ type mr2 is it?
richt1271
Postby adam2562 » Fri Dec 12, 2003 8:50 am
the bolts may be different
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby SC V6 » Fri Dec 12, 2003 9:44 am
Is there anyway to upgrade an Auto's flex plate?
Does this part apply to an auto... im almost positive it doesn't, but I had to check
thanks
Scott
SC V6
Postby Guest » Fri Dec 12, 2003 11:19 am
richt1271 wrote:if the clutch is the same as mr2..then the flywheel is the same as well?
I think the bolt pattern is different. If you're looking for a Fidanza flywheel, they have already designed one specifically for our application. If you order one for a Camry/Solara they should be able to get you one with the exact specifications.
As for the MR2, I think it's the '92 or '93, turbo version. If you go to Clutchmasters website, you'll see it listed.
Guest
Scottv6 wrote:Is there anyway to upgrade an Auto's flex plate?
thanks
Scott
No, this is for manual transmission only.
Guest
Postby cdssolara » Fri Dec 12, 2003 11:22 am
The last 2 posts were from me. I didn't get automatically logged in.
cdssolara
Postby Mole » Fri Dec 12, 2003 12:15 pm
thanks
Scott
no... we auto guys go for torque convertors.
Postby SC V6 » Fri Dec 12, 2003 1:12 pm
well.. I thought there was something that we could lighten that would have better throttle responce... Im already planning on the whole tranny rebuild and torque convertor.. but I thought something else could be done 2
later
Scott
SC V6
Postby richt1271 » Sat Dec 13, 2003 4:07 pm
still can't find a place to buy the flywheels sigh =( my clutch is going real bad now..
richt1271
Postby cdssolara » Sun Dec 14, 2003 1:41 am
Rich, were you able to contact Terry at the e-mail address that I gave you above? He was able to get one for me, although this was over a year ago.
cdssolara
