SolaraGuy.com • View topic - TRD Strut Bar vs. Stock Strut Bar
Postby SolaraT » Sat Jan 03, 2004 2:07 pm
8)
#1. Is there really a difference in the aftermarket TRD bar vs. the one that came with the Solara? Is it really that much stiffer to make a difference?
#2. Does the Solara not already have a stock RSB?
Please advice with your expertise.
Thanks,
Louis
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby geminimouse » Sat Jan 03, 2004 2:11 pm
The solara has a stock RSB but it's small in diameter (17mm i think). The TRD RSB is thicker (22 or 24mm i forgot). If u haven't lowered ur car yet and put the trd bar on, then u'll feel a BIG difference.
On the subject u put FSB, did u mean RSB?
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby SolaraT » Sat Jan 03, 2004 2:40 pm
No actualy I had questions for both. #1 is for the Front and #2 is for the Rear. You answered my #2. Thanks for the info.
2007 VW GTI
SolaraT
Postby Turbosolara » Sat Jan 03, 2004 3:34 pm
i am not sure if you are asking front strut bar or front sway bar. the strut bar serve all the same function, and there is no TRD front sway bar aviliable yet.
Postby SolaraT » Sat Jan 03, 2004 3:59 pm
Yeah the strut bar is what I am referring to. Is there really a difference between the stock one and the TRD one? .
I see that the Rear Stabilizer Bar is worth getting; however, in regards to the strut bar is it worth replacing it with the TRD one? I said FSB in the subject as Front strut bar but I guess there is no such acronym :lol: Sorry for the confusion.
2007 VW GTI
SolaraT
Postby solaraguy777 » Sat Jan 03, 2004 4:24 pm
I am 90% sure that there isent a difference between the trd and stock strut bars , the only difference is that the trd is made a little higher to go over the supercharger.
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby Yanks0114 » Sat Jan 03, 2004 4:40 pm
solaraguy777 wrote:I am 90% sure that there isent a difference between the trd and stock strut bars , the only difference is that the trd is made a little higher to go over the supercharger.
Essentially thats the main purpose of the TRD front strut tower brace, the stock one is fine
The TRD is taller to fit the SC and looks a little better. Thats it
Postby Mole » Sat Jan 03, 2004 4:44 pm
plus it looks like a weed whacker when you're holding one.
Postby Yanks0114 » Sat Jan 03, 2004 4:44 pm
geminimouse wrote:The solara has a stock RSB but it's small in diameter (17mm i think). The TRD RSB is thicker (22 or 24mm i forgot). If u haven't lowered ur car yet and put the trd bar on, then u'll feel a BIG difference.
The stock one is smaller than 17mm.
The TRD RSB is 19mm or 21mm depending if its on street or track
Postby Akui » Sat Jan 03, 2004 7:09 pm
Ok, could someone clear this up for me.
Apparently if you haven't changed the suspension on your solara and upgrade the RSB then you'll feel a great increase? I read Flipside's post on someone else's post concerning the TRD RSB and stock suspension where he said thought that upgrading the RSB on stock was not worth it. Anyone got an answer or more opinions to offer? Thanks.
Akui
Postby Mole » Sat Jan 03, 2004 8:26 pm
you have got to feel at least some improvement. just not the full on effect or limits of the RSB can handle if you had a modified suspension.
Postby geminimouse » Sat Jan 03, 2004 8:39 pm
08 Accord Coupe
geminimouse
Postby cdssolara » Sun Jan 04, 2004 1:41 am
Akui wrote:Ok, could someone clear this up for me.
The stock suspension is so soft that it gives the car a lot of body roll. An aftermarket RSB will really help with that, and in addition will reduce some of the understeer that is so prevalent in our cars. If you're really interested in improving the overall handling of your car, upgrading the springs and struts would be a great idea, too.
cdssolara
Postby Peter » Sun Jan 04, 2004 2:18 am
JIC also makes a front strut bar for out car, anyone have it? i was thinkin about buying it, but our stock one seems to be pretty strong already, i wonder if it would make a diff....
Peter's "Black Sheep"
Visit Black Sheep
Peter
Visit Black Sheep
Peter
