SolaraGuy.com • View topic - TRD Thermostat (Lower Water Temp 50-60 Degrees F)
Postby SolaraT » Sat Jan 03, 2004 5:40 pm
http://www.brandsport.com/trdj-16340-sp000.html
Does anyone got one of these? Seems like a good Product.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Mudd » Sat Jan 03, 2004 7:47 pm
No need. I'd just keep with the factory rated thermostat. There's a reason Toyota used it, which is the same reason you should use it too.
Mudd
Postby Yanks0114 » Sat Jan 03, 2004 10:54 pm
Mudd wrote:No need. I'd just keep with the factory rated thermostat. There's a reason Toyota used it, which is the same reason you should use it too.
Agreed. Unless you are having serious cooling problems, which I don't know of anywho who has had, there is no reason to change the thermostat.
Postby TadS » Sun Jan 04, 2004 12:55 am
I had a little problem with cooling (boil-off), but I swapped for a higher-pressure radiator cap and that seems fixed the problem. As for a thermostat, like said, seems like a bit of overkill man. I would just save money for the good mods :). I mean that's almost enough money for brake pads, or a RSB, or a FSB, or some SSB lines, or a couch dance or two. :)
TadS
Postby Yanks0114 » Sun Jan 04, 2004 10:50 am
if your car really is running too hot, try red line water wetter. It helped a lot for my friend's firebird
