SolaraGuy.com • View topic - Got new rims, had a question.
Postby krazeee1707 » Thu Jan 15, 2004 6:58 am
I traded my buddy for his axis se7en's. The rim size is 19x8. I'm not too sure if the offset is 40 of 45. The tire size is 235 40 19. First question is that if this will even fit on my car. If not, I can just sell them. Second question is that if anyone else has this same size/ rim on thier ride. Thanks in advance for the replies.
LOU
The rims are from this car.
http://www.pbase.com/image/10796654
krazeee1707
Postby Jackass-Jeff » Thu Jan 15, 2004 10:29 am
19x8 w/ 40 or 45 offset will fit with coilovers. If you're on springs/struts, then you may rub when cornering harder.
1GR-FE ftw!
Jackass-Jeff
Postby krawzyazn » Thu Jan 15, 2004 2:34 pm
click the www and you can see it on my car domain i have 19x8 axis se7ens with 40 offset 235/35/19
Postby krazeee1707 » Thu Jan 15, 2004 5:39 pm
are you having any problems with those se7ens on there??
krazeee1707
Postby krawzyazn » Fri Jan 16, 2004 1:00 am
little bit of rubbing so you gotta either roll your fenders cut them or get 225 tires
