SolaraGuy.com • View topic - quick question about RSB
Postby Akfahad » Fri Jan 16, 2004 6:03 pm
i got it today, planning on installing it tomorrow...but is there suppose to be any hardware with it, like screws or something like that for the install? they did send me 2 bushings, at least i think that's what they are.
Postby Mole » Fri Jan 16, 2004 6:09 pm
you re-use the stock rear sway bar bolts.
buy some good quality grease. ( i bought synthetic mobil 1 all purpose grease)
take my advice... use the grease it comes with, grab some plumber's tape, wrap it a few times over the grease, and apply more grease afterwards. it may be hard to fit, but trust me, its a pain in the arse when it starts to squeak.
Postby Akfahad » Fri Jan 16, 2004 6:49 pm
sweet, thanks
Postby Hsakuragi » Fri Jan 16, 2004 11:29 pm
have fun fighting to get that last one bolt in!~!
Hsakuragi
Postby Akfahad » Sat Jan 17, 2004 4:25 pm
well, i put the RSB in today...everything was fine except for the rusted nuts which was a pain. But, i wanted to put it on the track setting, but which one is it? Is the track setting the hole that's closest to the end of the bar or vice versa?
Postby xyntax » Sun Jan 18, 2004 12:12 am
closer to the bar is the track setting. notice that by bolting to that hole, it makes the bar shorter. the end holes make the bar longer.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby Akfahad » Sun Jan 18, 2004 9:22 am
thanks for the help
Postby Mole » Sun Jan 18, 2004 11:22 am
i would suggest setting on the out most hole first.
once you get used to the setting, then change into the inner most hole.
Postby Akfahad » Sun Jan 18, 2004 3:40 pm
to late... :)
Postby groovespacer » Tue Feb 10, 2004 1:40 pm
How do you like it on the track setting compoared to street? What is the difference in terms of ride quality and handling?
groovespacer
Postby Akfahad » Tue Feb 10, 2004 2:31 pm
since i didn't have it on street setting, i'm not really sure of the difference between the two, but the track setting is awesome, the car hugs the turns like it's nothin'...definitely tell the difference in cornering, that's for sure
Postby WTF?? » Tue Feb 10, 2004 2:41 pm
^^Im sure Kenny can answer that question of difference
I asked him at the central cal meet and he said there was a difference... so there ya go
Retired... its been fun Image
WTF??
Postby SC V6 » Tue Feb 10, 2004 2:42 pm
so the whole closer to the actual bar... closer to the middle... is the track setting??? I'm going to have to change that if thats the case
later
Scott
SC V6
Postby cdssolara » Tue Feb 10, 2004 4:30 pm
Scottv6 wrote:so the whole closer to the actual bar... closer to the middle... is the track setting??? I'm going to have to change that if thats the case
later
Scott
Yes, the outer hole is the street setting, and inner hole (closer to the middle) is the track.
cdssolara
Postby WTF?? » Tue Feb 10, 2004 5:35 pm
later
Scott
I did a search on this before and found the pic...
use it as an example...
http://www.zer0.info/solaraguy/viewtopi ... 53&start=0
the hole on the bottom is the "track" setting
done :D and enjoy your rsb!! :drinking:
WTF??
Users browsing this forum: Majestic-12 [Bot] and 71 guests
