SolaraGuy.com • View topic - Suspension
Suspension
Suspension
Postby PASolara » Sat Feb 14, 2004 3:17 pm
I just Bought Springs & Struts & TRD Rear Sway Bar, and Trd Suspension Bushings.. I was woundering if there was Anything Else I fogot And where could i get it Thanks IN Advance
This belongs in Aftermarket.
PASolara
Postby SolaraT » Sat Feb 14, 2004 8:21 pm
You can get a front sway bar from Whiteline but I heard that its problem causing going outof control and getting into accidents. Now that I think about it more there is a reason why TRD does not make it. I did my brakes @ Toyota yesterday and the 10 year toyota parts guy said that he was surprised that TRD did not make one for the Solara as TRD usually sells the sway bars in a set front and rear. He said that there must be a reason behind it and that maybe it's already strong and safe enough for the Solara. He said that the sway bar can't be too stiff because it will not let the independent suspension to work properly.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby PASolara » Sun Feb 15, 2004 6:52 am
Oh OK thanks So i Guess I have Everything they make then Cool... I just wanted to make Sure that I didnt MIss Anything :P
Oh Yea Is My stock strut Brace good enough or should i get a new one?
PASolara
Postby DavPak » Sun Feb 15, 2004 7:20 am
100shotSolara wrote:Oh Yea Is My stock strut Brace good enough or should i get a new one?
do you mean your front strut-top bar?
if so, the stock one is fine, some of us have the TRD one only because the stock one will not accomodate the supercharger, besides, it comes with the s/c!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Mole » Sun Feb 15, 2004 1:02 pm
hhah... yeah, "i bought the s/c soley b/c of the trd strut bar!"
Postby nkx1 » Sun Feb 15, 2004 5:12 pm
I'm thinking about lowering my car too. What is the advantage of buying new bushings, and do they have to be installed at the same time as the shocks and struts?
2001 SLE, Diamond White Pearl
nkx1
Postby TRD_solaRa » Sat Feb 21, 2004 2:53 pm
TRDMole177 wrote:hhah... yeah, "i bought the s/c soley b/c of the trd strut bar!"
Wutt??!?? So when I buy a TRD Kazuma Supercharger . . . I can get a strut bar with it?? Free of charge that is of course? Cause if the TRD front tower bar comes with the TRD supercharger that would be awesome . . . lataz.
. . . d . . .
TRD_solaRa
Postby impactX » Sat Feb 21, 2004 3:47 pm
Comes with the supercharger... it's not THAT awesome considering that they just add the price of the strut bar to the price of the SC.
impactX
Users browsing this forum: Majestic-12 [Bot] and 67 guests
