SolaraGuy.com • View topic - Lowered suspension specifications
Postby flybigjet » Sat Feb 21, 2004 8:08 pm
For those who were needing this information- these are the numbers I used for my '99 Solara SE V-6. Installed componants included TRD front strut brace, TRD rear sway bar (track setting), Whiteline front sway bar, Energy Suspension bushings/brackets, Eilbach springs, Bilstein shocks, 17x8 wheels and 225/45/17 tires. In order to adjust properly, struts were slotted to allow for camber adjustment (although I believe there's now a kit available to do this). All settings were done by hand as a normal 4-wheel alignment computer was, to put it mildly, confused by the lowered suspension setup. It made a night and day difference; car handling is now extremely neutral- *significantly* different from just having the car dropped onto the lowered suspension; it also solved a few minor abnormal wear problems I was having with my tires.
L/R Front: (min/nominal/max)
Camber: -1.27, -0.52, -0.23
Caster: 1.38, 2.13, 2.80
Toe: -0.1, 0.0, 0.1
L/R Rear: (min/nominal/max)
Camber: -1.4, -0.65, 0.1
Toe: 0.1, 0.2, 0.3
Front: (min, nominal, max)
Cross Camber: -0.75, 0.0, 0.75
Cross Caster: -0.75, 0.0, 0.75
Total Toe: -0.2, 0.0, 0.2
Rear: (min, nominal, max)
Total Toe: 0.2, 0.4, 0.6
Hope the information is of use. R.
"Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup."
http://www.cardomain.com/id/flybigjet
flybigjet
Postby boneezy » Sun Feb 22, 2004 12:07 am
SWEEEEEEET!... GRIPLOAD of thanks rod.. good crap
1999 SE-V6 5spd
160,xxx miles
boneezy
Users browsing this forum: Majestic-12 [Bot] and 67 guests
