SolaraGuy.com • View topic - Air Fuel gauge installation?!?
Postby swimshady906 » Wed Feb 25, 2004 1:57 pm
For those of you who have done this or know how.... where did you install the sensor wire? Is it the blue, white, or one of the two black? I tried the blue first and it gives too low a reading, so i tried the white and it seems to be correct accept when i give it any throttle atall it just goes to max on the rich area... do i need a wideband converter ... soemnthing like that? Or is it one of the black wires? Please help. :D
02' S2000 Silverstone
swimshady906
Postby swimshady906 » Wed Feb 25, 2004 10:37 pm
NVM .... O2 sensors are useless, i tapped the ecu and it works awesome-ly.
swimshady906
Postby Mole » Wed Feb 25, 2004 10:53 pm
which wire did you tap into?
Postby SolaraT » Fri Feb 27, 2004 3:51 pm
yeah which one? I need to get one now that I'm custom conecting a cold air extention.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby thakidd » Sat Mar 20, 2004 3:13 pm
yea which wire.and do you have a diagram for the ecu
thakidd
Postby swimshady906 » Sun Mar 21, 2004 1:08 pm
swimshady906
Postby Yanks0114 » Sun Mar 21, 2004 4:30 pm
I see the diagram but what wire did you tap?
Postby dan99solara » Sun Mar 21, 2004 4:55 pm
i think its the one he circled...
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby swimshady906 » Sun Mar 21, 2004 5:05 pm
dan99solara wrote:i think its the one he circled...
Bingo. and the one with the x through it.... is wrong that was a misteak.
swimshady906
Postby mlimin » Sun Mar 21, 2004 9:54 pm
So the right wire is the one he circle?
mlimin
mlimin
Postby SolaraT » Mon Mar 22, 2004 7:35 am
I guess thats for cali edition? which one 4 all other 49 states?
The wire color would also help give a confirm that we taped the right one. hehe :wink:
2007 VW GTI
SolaraT
Postby SC V6 » Mon Mar 22, 2004 3:08 pm
can anyone confirm which wire is it that needs to be tapped for non CA cars? thanks
I just ordered my air fuel gauge... so.. Im going to install it this weekend.. so it would help me out quite a bit.. thanks
Scott
SC V6
Postby SC V6 » Mon Mar 22, 2004 4:21 pm
Did you just keep trying wires? was this a stab in the dark or was this actually a good attempt? Just want to make sure that this won't be tapping the wrong thing... so its an ACTUAL reading, not just a wire that works.. thanks
SC V6
Postby SC V6 » Mon Mar 22, 2004 5:32 pm
after looking at the pages that joe posted here http://users.adelphia.net/~jbailer/ECU_pinout_1.gif
http://users.adelphia.net/~jbailer/ECU_pinout_2.gif
It seems to me like it wouldn't be that spot... I went to
http://www.egauges.com/pdf/AutoMeter/837j.pdf
and at the bottem it tells you the voltage readings and where those would read on the gauge.. and it doesn't even go past 1 volt... Im so confused.. because according to those ECU pinouts it says that the voltage for E10-12 it says that it has a constant voltage regardless of what the sensor tells the ECU... so... I dunno... maybe u can explain this to me
later
p.s. at the top of the second page it has a sensor labeled oxs. which I was thinking to be the oxygen sensor.... that is E8-8
I dunno.. maybe someone can help explain this
later
Scott
SC V6
