SolaraGuy.com • View topic - Once you are lowered....
Postby swimshady906 » Sat Feb 28, 2004 5:48 pm
Has anyone needed to buy a camber adjustment kit ? My front wheels butterfly like nuts... . :( i need new tieres after only a year on 280 treadwear....
02' S2000 Silverstone
swimshady906
Postby Mole » Sat Feb 28, 2004 8:04 pm
get the camber kit. looks like you def need one.
how low are you? or should i say what are you lowered on?
Postby swimshady906 » Sat Feb 28, 2004 10:13 pm
Just tien SS and tokicos... nothing crazy or even that great ... :roll: iuno
swimshady906
Postby cdssolara » Sat Feb 28, 2004 10:28 pm
If your drop isn't that low, then you shouldn't need a camber adjustment. My car's been dropped with Eibach and Tokico for 2 1/2 years and my tire wear is fine, with no camber adjustment. Where are your tires wearing?
cdssolara
Postby indiglosolara » Sat Feb 28, 2004 10:36 pm
swimshady906 wrote:Just tien SS and tokicos... nothing crazy or even that great ... :roll: iuno
i have the same set-up but i dont get that problem...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby bkp_duke » Sun Feb 29, 2004 1:31 am
TRD Springs and Struts and I had to put the kit on. Trying to get a left pull and rattle resolved right now, so make sure the show knows what they are doing.
bkp_duke
Postby all_red » Sun Feb 29, 2004 2:29 am
I went for an aligenment after I put on the Eibach/Tokico combo and they told me that I need that camber kit only for the left side and that it was off by some angle, but I didn't get that. I think I just have to wait and see.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby B_Master_Flash » Sun Feb 29, 2004 3:43 pm
Ok, I can't be the only person who has heard this.
When I got lowered, my camber was a little negative, but still within factory specs. The mech told me that it was fine to drive and it would handle great, but the tires would wear a little faster. he showed me on his computer, I could order a new set of bolts (the ones that hold the A-arm to the Strut) that would correct the problem.
Am I really the only person who has heard this?
B_Master_Flash
Postby LifeguardSLE V6 » Sun Feb 29, 2004 7:48 pm
No....I had the same problem. This was discussed recently in the Gen 1.5 section. My Solara had to have the camber kit put on after it was lowered because the camber was way off. I think it's a problem from the factory, and lowering just makes it noticeable. This is just one of those problems that no one really knows or cares about until it starts happening more and more.
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby swimshady906 » Sun Feb 29, 2004 10:15 pm
all_red wrote:I went for an aligenment after I put on the Eibach/Tokico combo and they told me that I need that camber kit only for the left side and that it was off by some angle, but I didn't get that. I think I just have to wait and see.
The right side is ok, it really is the left side that is totally worn... the inside of the tire is work to the cords and the outside is got about 75% tread left....
swimshady906
Postby all_red » Sun Feb 29, 2004 11:05 pm
MAN!! that gotta suck.. you need new tire when you already have 75% tread left.. I feel sorry for you.. I hope mine is not that bad..
5-speed V6.
TRD Supercharger.
all_red
Postby kondo » Mon Mar 01, 2004 12:26 am
I had a camber kit put on when the shop lowered my car.. I guess it works I dont have any issues with tire wear except i leave too much rubber on the pavemnt from doing burnouts.
99 sle, 03 evo
kondo
SolaraGuy StickerGuy
Users browsing this forum: Majestic-12 [Bot] and 56 guests
