SolaraGuy.com • View topic - Creaking/Clicking Noise
Postby indiglosolara » Sun Feb 29, 2004 7:04 pm
Ok, I went and got my my TRD Front strut bar installed last week and i've been driving it with no problems the first 2 days. Then my car sat in my garage for about 3 to 4 days and i decided to take it out this weekend.. I drove it on sat with no problems then today i was pulling into my driveway and now i hear a light creak/clicking noise. It kinda sounds like when your springs are getting compressed or when you are putting too much strain on your suspension.
Has anyone had this problem..??? I mite just put some grease around the bolts and lub my suspension to see if it helps.
Thanks in advance for your reply..
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby all_red » Sun Feb 29, 2004 9:28 pm
I get exactly what you described. I don't have the strut tower brace. I personally think its the strut mounts, I'm not sure though.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby krawzyazn » Sun Feb 29, 2004 10:46 pm
mine creak in the rear pass side
Postby kondo » Mon Mar 01, 2004 12:29 am
I had it..it means that your sway bar is not on straight...with mine it was the RSB, I took it back to the shop that put it on; they put the car on the rack and straightend it and I have not had any issues since.
99 sle, 03 evo
kondo
SolaraGuy StickerGuy
Postby LifeguardSLE V6 » Mon Mar 01, 2004 7:56 am
I have the same problem, except mine's the front right. I don't have a FSB or anything, and it only seems to happen when it's cold out.
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby krook » Mon Mar 01, 2004 2:28 pm
i get that too. and it increasingly gets louder with each bump i take. it happened right after i put my Tein/Tokico's on. i thought it was the strut mounts too. i took apart my whole backseat JUST to get to the strut bolts and tighten them to specs again.
turns out that wasn't the problem. i found out it was my exhaust hangar, which scrapes what i think is my tow hitch in the rear. figured that out when i was washing my exhaust one day....
krook
Postby indiglosolara » Mon Mar 01, 2004 8:28 pm
kondo wrote:I had it..it means that your sway bar is not on straight...with mine it was the RSB, I took it back to the shop that put it on; they put the car on the rack and straightend it and I have not had any issues since.
I dont have a front sway bar.. its the front strut tower bar.. but i put some grease where the bolts are to adjust the bar and it solved hte problem.. I guess it wasn't lubbed correctly...
but i can tell that now my front kinda creaks due to it being stiffer in the front. I know that the front strut bar doesn't do much affect but for looks.. it just seems to be a little stiffer. again its probably just me and not the strut bar.
indiglosolara
Solara 2 xB
Solara 2 xB
Users browsing this forum: Google [Bot] and 41 guests
