SolaraGuy.com • View topic - new rims
new rims
new rims
Postby LifeguardSLE V6 » Tue Mar 02, 2004 8:59 pm
To my surprise this morning, I went out to my car, and found the rear left tire fully deflated. Turns out, there were 7, yes 7 nails in that one tire alone; God only knows how many are in the others. So now I'm forced (oh darn) to get new rims and tires. I've pretty much decided on this wheels: www.wheelsnext.com/prod_imgs/img-178-large.jpg
They come with 205/40/17 tires, will those work? Any input on the rims is appreciated.
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby Mole » Tue Mar 02, 2004 9:14 pm
interesting design. however what's offset?
the width of the rim seems a little thin imho. since it only req's 205 tires.
Postby LifeguardSLE V6 » Tue Mar 02, 2004 9:30 pm
I just talked to someone in sales, and they said it was a 17x7.5 wheel. But it doesn't matter now, since they're also discontinued. Since I need rims immediately, any input from anyone on 17" rims will be of great help.
LifeguardSLE V6
Postby LifeguardSLE V6 » Tue Mar 02, 2004 9:44 pm
Sorry about these posts that're back to back, but I'm in a bind trying to get rims ASAP. I found some sweet looking BSA rims, which also come with 205/40/17 Nanking tires. The offset is 38 to 40. Pics are at www.wheelguyz.com/cgi-bin/prodspics/BSA291.jpg
LifeguardSLE V6
Postby krawzyazn » Tue Mar 02, 2004 10:04 pm
they look too cheap or not that strong looks like they will break easy not trying to be a dick but hey i wouldn't put that on my car
Postby Mole » Tue Mar 02, 2004 10:27 pm
they should fit with 205 for sure, but try to go 215
as long as its 5x114.3 with an offset of +38 to +45 you should be ok
Postby FLASH » Wed Mar 03, 2004 10:21 am
I'm not a LARGE fan of either, but I like the second ones more because they make the rims look bigger. The first ones look too...basic. However, its all a matter of personal opinion. They usually send tires with the 205/40/17 size because no one wants them...its a real thin tire and extremely low profile. They may be great for show, but if you're gonna drive with them, make sure ALL roads are PERFECTY flat!
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby impactX » Wed Mar 03, 2004 12:05 pm
They don't look that strong. With 205/40/17, they will be bent right away if you drive over potholes.
impactX
Re: new rims
Postby thealkimo » Wed Mar 03, 2004 1:20 pm
LifeguardSLE V6 wrote:They come with 205/40/17 tires, will those work? Any input on the rims is appreciated.
With 17s, IMO you're going to want atleast 215/45 or 215/50. Like the others said, 40 series does not provide enough cushion over potholes, plus they are lower profile than 45 or 50 and might actually make your rims look smaller since there will be a larger fender gap.
thealkimo
Postby impactX » Wed Mar 03, 2004 2:27 pm
Not to mention... you have to rev higher, and odometer turns faster than the actual distance you actually travel.
impactX
Postby SolaraT » Wed Mar 03, 2004 3:41 pm
impactX wrote:Not to mention... you have to rev higher, and odometer turns faster than the actual distance you actually travel.
yep it will be off and the rims look smaller. Our cars need bigger tires. Leave the 205/40 for more compact cars. Take a look at the web links forum for a site that you can compare upgrading wheels and tires. I'm to lazy to go back and post the exact site. Anyone else?
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby nkx1 » Thu Mar 04, 2004 1:28 pm
I agree with everyone else that 205/40 is WAY too small for a Solara. Geez, that's the size I used to have on my Integra. Before I upgraded to 18's on my Solara, I had 17's with 235/45 tires on them. They fit perfect, and seemed to match the overall stock diameter the best. If you get small tires like 205/40's, it will look dumb. Plus as others stated, the engine will need to rev higher, and you will rack up more miles on your odometer than you actually travel. So based on past experience, I recommend 235/45 tires for 17's.
2001 SLE, Diamond White Pearl
nkx1
Postby khanhdom » Thu Mar 04, 2004 7:59 pm
uhh yea...bigger tires, and both of those rims look horrible in my opinion....get some volks gtc (ones I use to have) or volks te37...they're pimp :P
khanhdom
Postby thealkimo » Thu Mar 04, 2004 8:38 pm
Check out this month's Super Street Magazine, there is an entire section dedicated to the hottest rims and tires available for 2004 8)
thealkimo
Postby HKSV6SLE » Fri Mar 05, 2004 12:53 am
those look like the sparco NT-r's....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Users browsing this forum: No registered users and 74 guests
