SolaraGuy.com • View topic - New Clutchmasters Stage 2 chatters
Postby nmatthis » Fri Apr 02, 2004 9:50 am
I just got a Clutchmasters Stage 2 clutch installed on my 99 Solara V6. I know it has to break in, but right now it chatters pretty bad when I try to feather it in first. Will this stop when it's broken in? Out of all the emails I read about people with this clutch, none said anything about chattering.
Neal
Neal Matthis
DWP 99 Solara SE V6 5-spd
TRD Supercharger (4 psi)
TRD struts/springs
TRD quickshifter
Whiteline RSB
160k+ miles
nmatthis
Postby cdssolara » Fri Apr 02, 2004 12:58 pm
That clutch shouldn't make any noise, at all. I had one installed over 1 1/2 years ago, and it never made a chattering sound, even when brand new. I'd take your car back to the place that did the installation, and have them look at it. Either they did something wrong, or you have a faulty clutch.
cdssolara
Postby nmatthis » Fri Apr 02, 2004 11:23 pm
Great. In first, I have to rev to about 1k rpm as I'm letting the clutch out to keep it from chattering. When it does chatter, it's not just a slight vibration. The car shakes. It's especially bad in reverse, where I really have to ride the clutch. Would a chattering new clutch be more likely a bad installation or a defective part?
Neal
cdssolara wrote:That clutch shouldn't make any noise, at all. I had one installed over 1 1/2 years ago, and it never made a chattering sound, even when brand new. I'd take your car back to the place that did the installation, and have them look at it. Either they did something wrong, or you have a faulty clutch.
Neal Matthis
TRD struts/springs
TRD quickshifter
Whiteline RSB
160k+ miles
nmatthis
Postby nmatthis » Sat Apr 03, 2004 12:13 am
One other thing. The pedal is extremely soft. I was expecting the pedal to be at least a little heavier than with the stock clutch. But now, the pedal is extremely soft. Is that normal?
Neal Matthis
TRD struts/springs
TRD quickshifter
Whiteline RSB
160k+ miles
nmatthis
Postby Mudd » Sat Apr 03, 2004 6:27 am
First off, if it's a high-performance clutch designed to hold any amounts of power over stock, it's going to chatter. That's normal. It gets better as you break it in. You may want to ask if your flywheel was resurfaced though - if it's not, that could be causing to clutch to not engage properly.
Mudd
Postby cdssolara » Sat Apr 03, 2004 9:15 am
nmatthis wrote:Great. In first, I have to rev to about 1k rpm as I'm letting the clutch out to keep it from chattering. When it does chatter, it's not just a slight vibration. The car shakes. It's especially bad in reverse, where I really have to ride the clutch. Would a chattering new clutch be more likely a bad installation or a defective part?
Neal
I can't answer your question about whether it's faulty or a problem with the installation. I can tell you that mine has never had a hint of chatter, and I've never heard of anyone else with a Clutchmaster Stage 2 having a chattering clutch. One of the things that Clutchmasters advertises is that you get significantly more holding power than with a stock clutch, but the pedal feel is similar to stock. When I first had mine installed, I could barely notice any difference in pedal feel between it and my stock clutch. It maybe was a little firmer, but not much. This clutch should not feel like a racing with more abrupt engagement and an overly firm pedal feel. If it does, or if your chattering continues, there's something wrong.
cdssolara
Postby nmatthis » Sat Apr 03, 2004 11:03 pm
Well, I guess I'll give it a couple hundred miles and see if the chattering stops. They did resurface the flywheel, but I wonder if I need a new flywheel. I went 90,000 miles on the original clutch and the mechanic said the clutch was pretty worn.
Regarding pedal effort, my new Clutchmasters clutch has significantly LESS pedal effort to operate than the stock clutch had, which was opposite what I was expecting.
Thanks very much for the responses.
Neal
Neal Matthis
TRD struts/springs
TRD quickshifter
Whiteline RSB
160k+ miles
nmatthis
