SolaraGuy.com • View topic - energysuspension Bushings
Postby PASolara » Sun Apr 04, 2004 3:01 pm
Hi i have 2001 solara se I was woundering if any of these bushings from the camry would work on my car.. Thanks in Advance http://www.energysuspension.com/toy.html
PASolara
Postby Mole » Sun Apr 04, 2004 3:06 pm
you should proof read what you type before posting.
assuming if you are wondering if these things fit for the mcv20L frame, they should.
the camry is the same part number listed at the bottom for the solara.
Postby SolaraT » Sun Apr 04, 2004 3:14 pm
Not think, scroll all the way down. Its exactly the same so it should work. I belive the only difference between the Solara and the Camry is the body molding and the fact that its a 2 door vs 4 door.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby PASolara » Mon Apr 05, 2004 2:39 pm
Thanks for the Input I ordered both The Front and Rear Controll Arm Bushings.
PASolara
