SolaraGuy.com • View topic - Wiring: Three Optima Yellow Tops
Postby Jon11582 » Fri Apr 23, 2004 7:34 pm
http://www.sounddomain.com/shoplist~b~O ... ~Batteries
Would any of these work without having to rerun the wires?
Found a local deal on Yellow tops, but only want one if it fits in without rewiring.
Thanks in advance.
2000 Black Solara SE
Jon11582
Postby Yanks0114 » Sat Apr 24, 2004 2:01 pm
No, but the get the optima orange top. It is equal to the red top but it is reverse polarity so it fits our cars no problem
Postby Jon11582 » Sat Apr 24, 2004 7:46 pm
51RD (middle one) is also reverse polarity. Wouldnt that work?
Jon11582
Postby Yanks0114 » Sun Apr 25, 2004 10:17 pm
Jon11582 wrote:51RD (middle one) is also reverse polarity. Wouldnt that work?
Theorhetically yes, but the dimensions are off.
Postby Jon11582 » Sun Apr 25, 2004 10:54 pm
Ah I see. I suppose the orange top has the same dimensions, or similar to our OEM battery then. Ive never heard of this one, but I guess ill keep an eye out for this one if I see it.
Thanks for the insight
Jon11582
Postby ZXLNT » Mon Apr 26, 2004 6:17 am
If they would make dual post battery wired to fit the Solar that would be great..
ZXLNT
Postby Paladin06Greg » Sat May 22, 2004 5:18 am
8) I just got the RED Top and with a minor modification it works and looks great!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby WortownSolara » Sat May 22, 2004 6:32 am
my only question is why 3?? Batteries are a band-aid, even the largest custom systems we do here only end up with 2 at the most, one for the vehicle, one for the system, Rockford makes some INSANE caps, 50 farad is not bad money and they were able to run a F-350 DIESEL off it for 3 days (no battery in the truck at all) Not to mention with one of these you wont have to kill the weight on the vehicle, you would be surprised how much it effects the ride quality. The absolute best way to gain more power is an alternator upgrade, for the price of 3 batteries its almost the cost of a larger alternator, plus if there is anyone around you that reworks alternators, you can get 30 more amps out of our stock one, and they usually only charge a doller a wind. Just some info guys.
Marc
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby Fenix » Sat May 22, 2004 7:44 am
WortownSolara wrote:my only question is why 3?? Batteries are a band-aid, even the largest custom systems we do here only end up with 2 at the most, one for the vehicle, one for the system, Rockford makes some INSANE caps, 50 farad is not bad money and they were able to run a F-350 DIESEL off it for 3 days (no battery in the truck at all) Not to mention with one of these you wont have to kill the weight on the vehicle, you would be surprised how much it effects the ride quality. The absolute best way to gain more power is an alternator upgrade, for the price of 3 batteries its almost the cost of a larger alternator, plus if there is anyone around you that reworks alternators, you can get 30 more amps out of our stock one, and they usually only charge a doller a wind. Just some info guys.
Marc
I think what Jon (the original poster) meant was out of those three Optima yellow tops in the link, which one was best for him to buy.
R.I.P baby.
Here come the black on black 5spds. New era....
Fenix
Postby Paladin06Greg » Sat May 22, 2004 7:52 am
8) LOL..:-)
Marc
Paladin06Greg
Torqued Solara
Torqued Solara
Postby HKSV6SLE » Sat May 22, 2004 2:23 pm
iof your gonna ge a better battery better oiff getting an yellow or blue top..the red doesnt have much more power than our stock ones.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Paladin06Greg » Sat May 22, 2004 3:12 pm
8) Hummmmmm, not sure of your stock battery but this Red top has a lot more cranking amps them the stock required battery..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby krook » Sat May 22, 2004 5:09 pm
i wanted to get the Optima Blue top to match the color scheme i got goin' on with my engine bay. but aren't those for "marine" use. (ex. yachs, boats) would that make it useless for a car?
krook
Postby Paladin06Greg » Sat May 22, 2004 6:46 pm
8) Yea, that's why I got REd for the color scheme and high cranking powrer. The blue is for boats and such. I'm not sure if it will work in a car or not.
8)
krooked Solara wrote:i wanted to get the Optima Blue top to match the color scheme i got goin' on with my engine bay. but aren't those for "marine" use. (ex. yachs, boats) would that make it useless for a car?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby WunLoudSolara » Sat May 22, 2004 8:27 pm
I gotta blue top, works well, best thing bout em they got screw posts with wing nuts and regular posts, I just use the screw posts because,
1: all my connections are ring terminals so they fit right on there and
2: in order to disconnect the battery all you gotta do is unscrew two wing nuts and pull off the wires and its disconnected
2000 Toyota Solara SE V6
Injen CAI
Gredy Evo
2 Power HX2 15
RF Power 1500bd & 450s
Sony CDX-M850MP
200Amp EA Alternator
Optima Blue Top Battery
MB Quart Premium 6 1/2 Components
WunLoudSolara
