SolaraGuy.com • View topic - Quickshifter's speed clip removal
Postby thealkimo » Sat May 01, 2004 6:10 pm
I've read the threads, but can't find anything solid. I'm trying to install my TRD quickshifter and am having trouble getting the cotter pin and speed clip off. What should I use?
Also, if anyone has any further instructions or tips on installing the quickshifter to speed up the process that'd be great. Many thanks!
thealkimo
Postby SolaraT » Sat May 01, 2004 6:46 pm
I am 100% sure someone will be able to help you with this. Congrats on your new upgrade! :D
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby all_red » Sun May 02, 2004 3:33 am
It took me an hour to install the shifter... 40 mins trying to figure out a way to take off that speed clip off. Since you got a new one with the kit already, try breaking the old one using two screw drivers - one small and another big. It'll work eventually. As soon as you get done.. the rest is just what putting the parts together again.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby thealkimo » Sun May 02, 2004 11:29 am
solarat wrote:I am 100% sure someone will be able to help you with this. Congrats on your new upgrade! :D
Thanks, looking forward to using it once its installed :D
But for the moment, I've gotten the speed clip off but need to know if I need to remove the small metal tube (part of the hinge) in order to take out the old stick cuz I can't seem to angle it right for it to come out easily. Suggestions?
thealkimo
Postby all_red » Sun May 02, 2004 1:49 pm
yep, just take it out. remove that whole white plastic piece holding the shifter from the top.
5-speed V6.
TRD Supercharger.
all_red
