SolaraGuy.com • View topic - 19 inch tires suggestion
Postby Ryan » Wed Jun 16, 2004 8:40 am
Okay I just ordered new 19's for my Solara but im really afraid that I might bend or crack this rims with 235 series tires cause the roads that im going through on a daily basis are just awful are there any 19" tires size that would fit and provides more rubber for my 19's???
Ryan
Re: 19 inch tires suggestion
Postby indiglosolara » Wed Jun 16, 2004 9:13 am
jojoy wrote:Okay I just ordered new 19's for my Solara but im really afraid that I might bend or crack this rims with 235 series tires cause the roads that im going through on a daily basis are just awful are there any 19" tires size that would fit and provides more rubber for my 19's???
235/35/19 is the ideal size.... depending on the width of your rims..
235 is the width.. ideal for 8 wide and higher... 35 series which is the side wall.... not much rubber there
im running 225/35/19 and im dont have any problems.. but then again i dont use my car for daily driving anymore...
i have 19x7.5 with toyo proxes...
you shouldn't have any problems with 235 tho with the right offset rims.. you mite need to roll your rear fenders if anything...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby MalBandito99 » Wed Jun 16, 2004 9:20 am
Is daily driving 225/35/19 that bad? NYC, nearby NJ roads, and many other areas where there are ghetto roads that you drive 80% of the time should be a no-no for driving with 19s.
I just ordered a set of forged 19x7.5" with 40% ghetto road ridin'. If you go with an over-oversized rim like 19, the least I would suggest is get a forged wheel. Check out http://www.centerlinewheels.com for some decently priced , quality forged rims. This is one company many people have been sleeping on as far as rims go. I don't know why I don't see more +offset riders using their stuff.
MalBandito99
Postby Ryan » Wed Jun 16, 2004 9:23 am
gosh maybe I should get a beat up daily driver my solara is going to look so hot with 19's
Ryan
Postby indiglosolara » Wed Jun 16, 2004 9:37 am
MalBandito99 wrote:Is daily driving 225/35/19 that bad? NYC, nearby NJ roads, and many other areas where there are ghetto roads that you drive 80% of the time should be a no-no for driving with 19s.
I just ordering a set of forged 19x7.5" with 40% ghetto road ridin'. If you go with an over-oversized rim like 19, the least I would suggest is get a forged wheel. Check out http://www.centerlinewheels.com for some decently priced wheels, quality forged rim. This is one company many people have been sleeping on as far as rims go. I don't know why I don't see for +offset riders using their stuff.
yea.. it all comes down to how bad the roads are in the area. Where i live in CA its not that bad.. I drive my solara on the weekends and i dotn run into problems. I just perfer not to park my car where i work since its a high traffic parking lot. Very busy shopping center.
But 19 wheels should be find witht he right tires...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SoLaRa_PimPin99 » Wed Jun 16, 2004 1:56 pm
I have 19's myself and i went with a 215/35/19 because i have 1.6" drop! my car looks clean and i think i went with the right tire size and i don't rub. If it is dropped or plan on lowering it 215/35 is probbly the way to go!
99 Solara SE V6 Black w/ Blue Pearl (New Paint job)
19" Niche F-16 (215-35-19 Nitto gen's)
Eibach Pro-kit
Tokico Blue Struts
Dual Cat-back Exhaust
Altezza Carbon Fiber tailights
SoLaRa_PimPin99
Postby indiglosolara » Wed Jun 16, 2004 2:00 pm
SoLaRa_PimPin99 wrote:I have 19's myself and i went with a 215/35/19 because i have 1.6" drop! my car looks clean and i think i went with the right tire size and i don't rub. If it is dropped or plan on lowering it 215/35 is probbly the way to go!
215 is used with rim width around 7inches or less.. i have 7.5 and 225 is pushing it... the tires kinda curves in and make your rim more pron to be dented or bent if you hit a pot hole..
what size, width are you getting...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby MalBandito99 » Wed Jun 16, 2004 4:26 pm
Hmmm, so what size tire do you recommend from your experience for my 19x7.5" wheel? 235? I was going for 225 but I can change.
MalBandito99
Postby indiglosolara » Wed Jun 16, 2004 4:30 pm
i would say go with 235 to be on the saer side. I have 225/35/19 right now and its not that bad but i wish i would have gone with 235 instead.. My next set of tires i will have 235.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby MalBandito99 » Wed Jun 16, 2004 4:36 pm
Ill investigate this more, but your claim is getting me to think twice. Its just that tirerack.com recommends the tires I'm getting to go on a 7.5-9 width rim. The 235 size of this tire would take 8-9.5 width, just .5 bigger than my rim's width. I hope they got a return policy or something because if it doesnt fit right after putting them on the wheel.....
MalBandito99
Users browsing this forum: No registered users and 75 guests
