SolaraGuy.com • View topic - Suspensions
Suspensions
Suspensions
Postby SleeperSolara » Fri Jun 18, 2004 8:46 am
Which gives you better handling: Eibach or Intrax or H&R or B&G??
Where can i get some TRD sway bars??
Is the stock strut bar/brace good as it is stock, or should i get a different one. Where can i get some slotted/drilled brake rotors; which ones are the best??
Where can i get some white face gauges??
How do i fix my 6cd changer; the problem: when i start the car the cd trays move, but i can't stick a cd in the player; how do i fix that, is there a reset button on the back of the cd player of what.
Re: Suspensions
Postby Jackass-Jeff » Fri Jun 18, 2004 9:40 am
Which gives you better handling: Eibach or Intrax or H&R or B&G?? Springs and Strut upgrades = almost the same... get coilovers if you want real handling capabilities =P
Where can i get some TRD sway bars?? www.toyotaparts4u.com $155 shipped.
Is the stock strut bar/brace good as it is stock, or should i get a different one. The TRD one is only made to fit over the supercharger... other than that, it's totally useless... it's only for looks.
Where can i get some slotted/drilled brake rotors; which ones are the best?? Brembo has slotted/drilled, I think. You don't have many choices here... I think Brembo also makes a big brake kit (that didn't sell)
Where can i get some white face gauges?? www.procarparts.com or eBay
How do i fix my 6cd changer; the problem: when i start the car the cd trays move, but i can't stick a cd in the player; how do i fix that, is there a reset button on the back of the cd player of what? That's not aftermarket, buddy =P
1GR-FE ftw!
Jackass-Jeff
Re: Suspensions
Postby TadS » Fri Jun 18, 2004 6:23 pm
SleeperSolara wrote: Where can i get some slotted/drilled brake rotors; which ones are the best??
The tirerack.com has EBC rotors. Nopi has Powerslot and Powerstop. Then there is of course Brembo. I would check groupbuycenter.com for those.
TadS
Postby Mole » Fri Jun 18, 2004 6:46 pm
i have powerslot rotors and i have liked them very much in combonation w/ SSB brake lines and ebc GREEN stuff brake pads.
w/ that i've felt the most improved braking on my car.
i've mauled through TRD, EBC red, and in the process of mauling through porterfield which imho aren't that great.
porterfield is a local company for me, down in irvine/oc area. thought they would have some good stuff, but its just not working for me.
Postby sackings2003 » Fri Jun 18, 2004 11:39 pm
The Bogey Man wrote:i have powerslot rotors and i have liked them very much in combonation w/ SSB brake lines and ebc GREEN stuff brake pads.
I have a question. For the "powerslot rotors", are you only installed the front two or all four??
1999 Solara, Red Flame Metalic, SLE V6.
sackings2003
Postby Mole » Sat Jun 19, 2004 1:56 am
front and rear.
Users browsing this forum: No registered users and 75 guests
