SolaraGuy.com • View topic - Changing Rotors
Changing Rotors
Changing Rotors
Postby whiteflash » Wed Jun 23, 2004 11:30 am
How much would you say I shop charge to Change All four of my rotors....basically labor only?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby MGLax13 » Wed Jun 23, 2004 3:50 pm
It's a real easy DIY. If you need help, you call me, I live close.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Turbosolara » Wed Jun 23, 2004 4:22 pm
It is recommend to change the pad at same time
Re: Changing Rotors
Postby sackings2003 » Wed Jun 23, 2004 4:53 pm
whiteflash wrote:How much would you say I shop charge to Change All four of my rotors....basically labor only?
I'm going to have the same project. Which brand of rotors you are going to choose?? :D
1999 Solara, Red Flame Metalic, SLE V6.
sackings2003
Postby that1mexguy » Wed Jun 23, 2004 4:57 pm
I'd say you guys should try to change them yourselves. I am a complete moron when it comes to do stuff like that, yet i just recently changed my pads and removed the rotors (just to see how hard would it be to change them), and believe me, it was not hard at all.
that1mexguy
Postby bassthrive » Wed Jun 23, 2004 5:28 pm
How hard is bleeding the brake lines after the install?
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby boneezy » Wed Jun 23, 2004 6:59 pm
bassthrive wrote:How hard is bleeding the brake lines after the install?
- Paul
lol.. you need a friend.. trust me.. lol
but the procedure itself is painless, 10minutes
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby gnaw_divad » Wed Jun 23, 2004 8:03 pm
I've gone through the process and unfortunately i was not one of those people who read the instructions first. Bleeding your break lines is no problem IF YOU DONT REMOVE YOUR CALIPER (usually for painting), but if you do and all the break fluid gets out be prepared to pump you A$$ off.
Also there are some techniques that'll make the job must easier, the procedure is written in detail in the CAMERY/SOLARA hagnes manuel, i suggest you get it, it comes in handy. I believe, (not positive) if you only change the rotors and pads and you leave all the break lines in place by hanging the caliper, you actually dont really need to bleed the breaks. But if you do, it'll be pretty simple since not to many air bubbles can get in unless you unhook the hose.
P.S. If your only changing the rotors and pads, its cake. Check the DIY section, there are some good instructions.
-David
gnaw_divad
Postby whiteflash » Thu Jun 24, 2004 5:57 am
hey that1mexguy whats your number?
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby that1mexguy » Thu Jun 24, 2004 6:58 am
whiteflash wrote:hey that1mexguy whats your number?
see if this helps a little at least:
http://www.zer0.info/solaraguy/viewtopi ... ght=#90035
that1mexguy
Postby TadS » Thu Jun 24, 2004 8:19 am
I did mine, you can see some pictures and whatnot here. Its's very simple if you don't paint, as you shouldn't need to bleed or anything.
http://www.angelfire.com/mech/tadsolara/Install/front_brakes/front_brakes.htm
Good luck!
TadS
Postby whiteflash » Thu Jun 24, 2004 9:22 am
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby impactX » Mon Jun 28, 2004 12:45 pm
What a rip, I got my Supra TT rotors at 80CDN (around 60USD) a piece which are directional and 12.7" in diameter.
impactX
Postby whiteflash » Mon Jun 28, 2004 3:12 pm
Can you take pic of your rotors upclose
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Users browsing this forum: Google [Bot] and 74 guests
