SolaraGuy.com • View topic - what can we do to beef up the engine
Postby supamouse09 » Mon Jun 28, 2004 11:21 pm
i was wondering what could be done to beef up the bottom end of the 1mzfe to make it handle high boost. like pistons? does anybody acutally make them for our car? any input would be greatly appreciated.
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby boneezy » Tue Jun 29, 2004 1:05 am
search it up, theres a couple guys in here w/ jim's stuff, which helps them runs more boost.
also check out shidosha01's stuff..hes running at a godly 10psi
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby Turbosolara » Tue Jun 29, 2004 2:09 am
you had transmission swap?
Postby supamouse09 » Tue Jun 29, 2004 2:30 am
as we are posting my transmission is being swapped. only waiting for the manual ecu and im up and running again.
supamouse09
Postby supamouse09 » Tue Jun 29, 2004 2:32 am
oh yeah hey joseph where did you get your indiglos at? i like them.
supamouse09
Postby SBCelicaGT » Sat Jul 03, 2004 1:50 pm
What do you consider high boost? What do you plan to do with the car? These are two very important questions you need to answer before deciding that the bottom end is too weak. Its been shown that the engine can handle close to double the stock hp without breaking. For how long? That depends on how well you manage the power.
That said, I think JE can get you custom pistons if you like.
stock 22RE con rods will fit with some machining done and can handle about atleast 300hp.
1990 Toyota Celica 1MZ V6
14.7@95mph @ Famoso
All motor. hehehehehe.
SBCelicaGT
Postby DatSRBoi » Sat Jul 10, 2004 6:36 pm
Upgrade is a pain when your broke. All ive done so far that i can afford is shown below. HOW do i even change the spark plugs in the back..darn intake manifold is in the way..Does NGK spark plug add power to a car?
Postby bassthrive » Sat Jul 10, 2004 6:53 pm
Plugs dont add power. Dont believe whats on the manufacturer's box.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Sat Jul 10, 2004 7:37 pm
plugs don't add power-correct, however it does make fuel burning more efficient.
(comparing old to new spark plugs)
Postby bassthrive » Sat Jul 10, 2004 8:25 pm
Yup, if your plugs are old and poopy you will regain lost horses. I was just saying that there is no such thing as a "performance" plug that will make your engine more powerful.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby JoeB » Sun Jul 11, 2004 5:31 am
To add to that, having the right plugs AND having them gapped according to the application is VERY important for power. -JoeB
JoeB
Users browsing this forum: No registered users and 75 guests
