SolaraGuy.com • View topic - 225/50/18?
225/50/18?
Postby MalBandito99 » Tue Jul 06, 2004 4:24 pm
No, you'd be 4.6% slower than stock, meaning the wheel would be bigger in diameter. 3% is the universal allowable, but I would allow +- 1.5%. Dont do it, theres a reason most 18" riders use 225/40.
And man you should of gone 19"... what were u thinking! :P
MalBandito99
Postby MalBandito99 » Tue Jul 06, 2004 4:34 pm
Yes, for a daily driver, you would especially not want to adjust to total diameter of the aftermarket wheel and tire from the stock wheel and tire. If you do, you will interfere with the transmission's shift points (leading to eventual failure), ABS malfunction as the wheel size is different than what the ABS is programmed to (I dont have to describe what could happen if your ABS failed in a situation while daily driving), along with many other things involved with the suspension. Oh yeah, and you'll def rub.
If 16s were fine, then I suggest looking for some nice 16s to keep the stock rubber you had and apparently need. Or maybe some 17s would do fine. 18s will bend as much as 19s would, so I dont see the big deal there. Look into forged rims. Sorry bro, not much else I can suggest. :(
MalBandito99
Postby SolaraT » Tue Jul 06, 2004 4:43 pm
no go 40
SolaraT
Solaraguy need mo power guy
Postby whiteflash » Tue Jul 06, 2004 6:29 pm
yea go 40 bro...
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Mole » Tue Jul 06, 2004 7:24 pm
hmm...
if the roads require you to use 50 series tires, then go for 17's at biggest.
Postby Yanks0114 » Tue Jul 06, 2004 10:23 pm
TRDMole177 wrote:hmm...
Agreed
Postby michaels artic frost » Wed Jul 07, 2004 5:21 am
Take heed on TRDMole177's advise. The 18s with those tire size are too big in diameter and will offset your speedometer.
Check out this site, it really helped me chose the right tires and wheel sizes.http://www.miata.net/garage/tirecalc.html
For instance:
Stock tire: 215/55/17 the diameter is 26.3
New tire: 245/35/20 the diameter is 26.8
That calculation stated that I would be 1 miles faster than what my speedometer was reading. However, I checked it and it's readin' correctly.
GL and hope this helped.
-Michael
Updated 06/01/12: Michael T's
Postby ICrazyChrisI » Wed Jul 07, 2004 3:52 pm
Just curious, does anyone know what size tires came on the TRD rims(TSW Revo)? Thanks
ICrazyChrisI
Postby SolaraT » Wed Jul 07, 2004 3:57 pm
225/45/17
Thats what I remember back in 99 when they were being sold in package.
SolaraT
Postby cam2Xrunner » Fri Jul 09, 2004 9:13 pm
235/40/18 is closer to stock diameter than 225/40/18. I will soon be switching over to the 235's
cam2Xrunner
Postby indiglosolara » Fri Jul 09, 2004 9:17 pm
trdcamry2003 wrote:235/40/18 is closer to stock diameter than 225/40/18. I will soon be switching over to the 235's
Werd.. im running 225/35/19's and im not satisfied with the look. I should have gon with 235/35/19.
on my old 18's...
i went with 225/40/18 and was ok.... bit if you can fit 235 nicely thats what i would go for.. not 225..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SolaraT » Sat Jul 10, 2004 6:43 am
Yep thats true. That's what I got.
SolaraT
Users browsing this forum: No registered users and 75 guests
