SolaraGuy.com • View topic - 4cyl Sparkplug Change
Postby quadra » Sat Feb 12, 2005 6:06 pm
I found a good spark plug replacement tutorial for a 4cyl at scionlife:
http://www.scionlife.com/forums/viewtopic.php?t=43053
I'd double check on the type of spark plugs to use. There's a sticker on my '02 solara under the engine cover which recommends using only Iridium type plugs.
If you get Denso / Iridium plugs (IK20), they also warn you Never use a round gapping tool to check the gap or to increase or decrease the gap setting.
They should come pre-gapped, so their warning to NEVER TOUCH THE ELECTRODE should be easy to follow.
quadra
