SolaraGuy.com • View topic - Oil filter study
Oil filter study
Oil filter study
Postby Turbosolara » Mon Feb 21, 2005 1:14 am
I think it is quite interesting....
However, i had been adivced that JDM OEM toyota filter is the best (made by Denso) and so does Honda's OEM filter
http://minimopar.knizefamily.net/oilfilterstudy.html
Postby Turbosolara » Fri Mar 11, 2005 2:10 pm
Postby Turbosolara » Fri Mar 11, 2005 2:15 pm
OIL FILTERS
Postby roger182nd » Wed Jan 23, 2008 7:07 am
I use the purolator pure one's. But since I have the 2002 solara with the V6, I use the taller oil filter. Why? (1) because it holds more oil. (2) More external surface area equals more efficent oil cooling. (3) a taller filter has more filter media inside.
I also took a BMW heat sink and placed it on the oil filter to disapate more heat.
Roger
roger182nd
Postby QuickSEV6 » Fri Jan 25, 2008 1:33 am
This is very interesting, but it never says which is the best and which is the worst.
It just tells you all about each filter.
I wanna know which is the best.
I've always used the K&N. I figured they make the best air filter, they should probably make the best oil filter. Well, the article tell me tha Champion actually makes the filter for K&N.
Damn outsourcing!!!!
Thats like letting Ford make some Toyotas.
Well, I'll stick with the K&N oil filter. I'm a creature of habit and I go with what I know.
