SolaraGuy.com • View topic - Kazuma TRD Supercharger Install Manual
Postby SpeedSTARs » Tue Nov 29, 2005 10:32 pm
Hello Ladies and Gents,
For those that are looking for it, here is the TRD SC manual below. I just found it.
:roll: Hopefully this helps some of you out. :angel:
Supercharger install DOC:
EBC & MISC stuff install DOC:
SpeedSTARs
Postby WTF?? » Wed Nov 30, 2005 10:09 am
hhaha good shyttt G!! :D
Retired... its been fun Image
WTF??
Postby DatSRBoi » Wed Nov 30, 2005 10:23 am
Im having issues with the non and cali specs.. Non Cali ask E7 pin 13 be tapped... But on my car.. E7 pin 13 has nothing in it.. No lines. I dont know if my car was built to cali specs or what? I dont wanna loose power and go with cali specs... And where is the ll2 harness located? Are these all located on the ECU?
Also on this one. I dont get how to tap the E8 pin.. Im so confused with E8, E7, and locations of ll2.... :( . The other 3 lines where easy. Or could it be because thats only camry only and solara runs off the same as cali specs so I tap it with the cali specs chart? but then again on the cali spec chart layout of the pins, E7 pin 13 on theres has a line and mine doesnt still... Im so confused now.
Postby Astro » Wed Nov 30, 2005 12:05 pm
Postby hskrsolara » Wed Nov 30, 2005 12:26 pm
dat, where did you get your sc?
hskrsolara
Postby bassthrive » Wed Nov 30, 2005 5:56 pm
wow that scan is so bad it makes my eyes hurt.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SpeedSTARs » Wed Nov 30, 2005 6:14 pm
:o Man.... :-?
Thank god Astro found the link... Thanks Astro. :wink:
As for the scan, the GIF file came out find in my side of things, But for some reason the pictures are lowsy (now that I've looked back). It must be Photobucket.com translation. :x :oops: :oops:
SpeedSTARs
Postby DatSRBoi » Wed Nov 30, 2005 11:27 pm
Im still having issues figuring out which wires go where on the manuel solara on non cali specs.. It just doesnt match..
Postby RichD978 » Mon Feb 12, 2007 4:36 pm
anyone have the pdf's saved?
RichD978
Postby that1mexguy » Mon Feb 12, 2007 5:00 pm
I only have the Instruction Manual (which I already sent to you) and EBC (if you need it) ... I'm going to start charging you!!! ... and only because it's obvious you've been doing your homework/search I'm willing to help you LOL
that1mexguy
