SolaraGuy.com • View topic - Cheap Faux Alarm Blinking Red Light
Postby noodlerooney » Tue Feb 07, 2006 7:53 am
I've installed this in many cars, red blinking light (security) that comes on when key is off and goes off when key is on, looks like a security light. Mount the LED where it can easily be seen from the outside of car, from the driver's side window.
B+ ---------> 470 ohm ----------> blinking red LED ----------> B+
constant_____.5 watt resistor_____RS #276-036, 5mm________w/KOEO
B+ constant: constant power = brakelights.
B+ w/KOEO: power when key on engine on.
You can by a 5 pack of the 5mm holders to mount the led on the dash, goes between the bulb and dash. Looks very realistic, cheap mod, < $5 total. Use a 1/4 inch drillbit to drill hole.
15,001 miles, Garage Queen
noodlerooney
Postby Midias » Sun Mar 02, 2008 3:46 pm
I already have a factory one in my gauge cluster is that a rarity.
Postby Jakecallun20 » Sun Mar 02, 2008 3:50 pm
I too have it in my gauge cluster, I just would like one on each door panel near the window for added protection. Found this and thought it seemed like a cool little way to make me feel better about my car.
Postby Jakecallun20 » Sun Mar 02, 2008 8:50 pm
bump...anyone know how I can set this up? I don't understand the stuff up above... Thanks
Postby LatinUSMC » Sun Mar 02, 2008 11:40 pm
i bought my hyper-bright led online and gave up and had it installed by local alarm guy for 20 bucks in 15 min...just take it to be done right w/o you blowing afuse or cutting/touching the wrong wires. :P
LatinUSMC
Postby DrLove » Tue Mar 04, 2008 12:29 pm
I dislike to read "cheap" and "Solara" in the same sentence :P :lol:
You can do one with a 5mm LED, a relay, 470 Ohms 1/4W. It will stop to light when you turn the key. Or buy one already made for some bucks.
Mazda 6 2010 6 speed black GS
DrLove
Postby SleeperSolara » Tue Mar 04, 2008 3:14 pm
I have a OEM alarm LED in my RPM gauge cluster.
But then again i have a aftermarket alarm wit a blue LED.
And my white reverse glow gauges cover the OME ones.
Users browsing this forum: Majestic-12 [Bot] and 11 guests
