SolaraGuy.com • View topic - Removing the orange color on your gauge needles
Postby hanatsuki » Thu Mar 16, 2006 12:15 am
Instead of sanding down the color, you can dip a q-tip in nail polish remover and gently rub underneath the needles until the color comes off. You will need to put some plastic wrap before you do it because the acetone will mess up the gauges (note in the picture the black on the gauge looks blotchy) I thought this might be a easier and less barbaric alternative to sanding lol :lol:
any nail polish remover should do, but just in case you guys still have no clue i used Salley Hansen Extra Fast Polish Remover with Vitamin E :wink:
What's hot, sexy and has a stick?
my solara v6
hanatsuki
Re: Removing the orange color on your gauge needles
Postby PXLpainter » Thu Mar 16, 2006 12:17 am
hanatsuki wrote:any nail polish remover should do, but just in case you guys still have no clue i used Salley Hansen Extra Fast Polish Remover with Vitamin E :wink:
LOL!! :lol:
It must be the Vit E that really makes it work! ;)
So straight Acetone just might work as well then too, right?
Postby SleeperSolara » Thu Mar 16, 2006 1:43 pm
Nice.
Last edited by SleeperSolara on Fri Mar 17, 2006 12:26 pm, edited 1 time in total.
Postby MikeATL » Thu Mar 16, 2006 1:49 pm
Yeah, but what does it look like at night?
MikeATL
Postby Assyrian » Thu Mar 16, 2006 1:54 pm
did the acetone make the plastic foggy looking?
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby DatSRBoi » Thu Mar 16, 2006 2:52 pm
Take pics of this at night for us.
Postby SolaraGuy22 » Thu Mar 16, 2006 3:02 pm
Damn it! I wish I knew that before I sanded mine. Those things look rough as hell.
Definitely take some night shots though.
Thanks for the tip.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby QuickSEV6 » Thu Mar 16, 2006 3:35 pm
SolaraGuy22 wrote:Damn it! I wish I knew that before I sanded mine. Those things look rough as hell.
Thanks for the tip.
I agree. I sanded mine and I don't like it.
Well, live and learn.
I'll have to buy a new gauge cluster now and try that.
Postby solaraheno » Thu Mar 16, 2006 8:13 pm
wondering how it lok like at the night time ~! :p
solaraheno
Postby hanatsuki » Thu Mar 16, 2006 8:42 pm
i havent done this on my actual gauges yet, i'll do it next weekend after finals. I should also be getting the led bulbs for it too by then :)
my solara v6
hanatsuki
Postby RichD978 » Sun Mar 19, 2006 10:00 am
any one have pics of this done yet
RichD978
Postby Duffman » Sun Mar 19, 2006 5:14 pm
I went to the Pick 'n Pull a couple days ago with a friend of mine and found one Gen 4 Camry - with its gauge cluster. The 97-01 Cluster is interchangeable with the 99-03 'lara; the only differences are 1) the font on the tach/speedo numbers, and the needles. The Camry gauges have white needles (white paint instead of the orange - NOT clear). I pulled my needles and replaced them with the white ones (still using stock bulbs, need to order some replacements!). All in all, it looks nice - it's classier, I think. I'll get some pics tonight and put them up. If you're not wanting to sand or chemically remove the paint, this is an alternative (I also wanted the spare cluster to experiment with, lol).
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby Duffman » Sun Mar 19, 2006 5:58 pm
I broke down and took some acetone to the red needles I had. The results were good, but not perfect (the acetone etched the plastic of the needles slightly). Also I was thinking - if they can put a colored paint on a needle, why can't we? It would be a simple matter of getting some thin acrylic paint and painting the back of the needle. It would take a steady hand, as they're pretty small, but I think it could be done.
Anyhoo, here's pics of what I've been playing with thus far:
White 97-01 Camry Needles on Solara Gauge Cluster, Daylight
White 97-01 Camry Needles on Solara Gauge Cluster, Daylight Detail
Orange 99-03 Solara Needle Backing, Detail
White 97-01 Camry Needles on Solara Gauge Cluster, Lit (Stock Bulbs)
White 97-01 Camry Needles on Solara Gauge Cluster, Lit Detail (Stock Bulbs)
Stripped 99-03 Solara Needle on Camry Gauge Cluster, Detail
Stripped 99-03 Solara Needle on Camry Gauge Cluster, Better Detail
Duffman
Postby DatSRBoi » Sun Mar 19, 2006 6:07 pm
Hmm not too shabby
Postby hanatsuki » Mon Mar 20, 2006 12:15 am
Duffman wrote:Orange 99-03 Solara Needle Backing, Detail
hey have you had any problems with the calibration of the needles when you take them out? I took them out on my spare cluster and wiped off the orange color and painted silver nail polish on the back but havent tried them out yet...
as for the splotchiness/etching the acetone leaves, you can try coating the needle with clear nail polish or varnish, which should make it nice and shiny
my solara v6
hanatsuki
